possible cause for 00297 audi a8 3.7 97
what are the the possible cause for 00297 for audi a8 97 3.7?
thanks in advance |
I'm guessing that you meant a P0297 code, which, after some quick googling is defined as:
Indicates the vehicle has been operated in a manner which caused the vehicle speed to exceed a calibration limit. The vehicle speed is continuously monitored and evaluated by the Power Train Control Module (PCM. The DTC is set when the vehicle speed exceed the calibrated limit set within the PCM.) Been on the Autobahn lately? :D l8r) |
I found a Vag code 00297 (IF that's what you meant), which tranlates to 3 P-codes:
00297 P0715 Input/Turbine Speed Sensor Circuit - Malfunction 00297 P0721 Vehicle Speed Sensor Circuit - Range/Performance - Signal Noisy (G38) 00297 P0722 Vehicle Speed Sensor Circuit - No Signal 00297 Transmission Vehicle Speed Sensor (G38) |
