Problem with suspension
Hello, I have a 2004 Audi A8L with 65k miles on it. I have started having problems with the suspension. I don't know if is a leak or its the sensors.
Some times it does not give any problems. Other times I started the car and after a few minutes of driving I get a yellow light indicating a suspension problem. If I go to car setup menu I have the car on dynamic, and all other options are greyed out. Sometimes I have two of the four options greyed out. I don't see the car sagging on any wheel. It is just low. Even with the options not greyed out the car will not raise to the higest position. Sometimes I also get a stability control yellow light on, then the next few times I drive the car it doesn't. What can be happening, it's a sensor/electronic issue? airbags? My car is just out of the extendend warranty (of course) what can I do? Juan |
Pretty hard to diagnose an $80,000 car by guessing, there are computers for just about every function on that car for a reason. You need to have the fault codes read.
The fact that the options for the suspension settings are being greyed out indicates the car is shutting off the system, it can be just about anything on THAT car. |
The same thing happened to my 2007 A8 with 55K miles. It turned out they had to replace the air suspension compressor and relay. Works like a charm now after spending $2,013!
I am having the same issue with the jack mode light on and greyed out settings....Did anyone ever figure out the issue?? I read on other forums it is more than likely the relay which caused the 40 amp fuse to blow? and stealers just like to change the compressor while their at it?
Vag Codes: 01777 - Level Control Accumulator Valve (N311) 009 - Open/short to ground and 01772 - Signal from level control pressure sensor (G291) 008 - Implausible Signal Any part number for the relay and schematics of the location? THANKS in advance for any help! |
Originally Posted by JLM04A8L
(Post 1336834)
Vag Codes: 01777 - Level Control Accumulator Valve (N311) 009 - Open/short to ground and 01772 - Signal from level control pressure sensor (G291) 008 - Implausible Signal Any part number for the relay and schematics of the location? THANKS in advance for any help! The 40 amp orange fuse under the steering column is good!!?? Thanks in advance! |
The relay is just above the fuse. The first one top left.
I have the old one I took out, it's from a 2004 and has the number 373 12V40A stamped on it. It was right above the fuse top left corner one. Audi sold me a new one when I bought a new compressor.
Originally Posted by grease
(Post 1337235)
Air Compressor Problems
Hello Everyone,
I have a 2004 Audi A8 L and seem to be having a very common problem which is car's suspension system not working properly. Yes! i am also seeing those yellow and green car lights on my dash and its moody because sometimes out of the blue it would just start working, but it has not done that lately and now the lights are just continuously blinking not sure what that means. A buddy suggested that I change my relay first as its only 28 dollars from the dealer. I don't want to and refuse to pay these pirates 2500 dollars to change my air compressor as they stated is the problem. But if that was the case how could my pump come back to life every now and then? so i am guessing it can also be a relay. What i needed to know is if any one can post the exact pic or directions for where the relay is located and which exact relay is it? I am not very techy or car savy but I am willing to give this a shot since paying 2500 would make anyone techy and savy. Please advise and Thank you in advance. |
Well.... the system is acting up because either the compressor has failed, or is failing, due to a leak.
Typically the relay gets burned out because the compressor runs so much, and will usually throw a DTC saying that it shut down due to overheating. You can try the relay but I doubt it's a long term solution. The leak should be fixed first if there is one. Sometimes the valve block also leaks or fails. Then move on to the compressor if it has seized or failed by rebuilding or replacing. A full Auto-Scan is your best bet before throwing parts at it any more expensive than that relay :) Edit: ps - the explanation of the two lights flashing is in the manual, but I can't for the life of me remember what it means pps - is one, or several, of the corners of the vehicle sagging or lowering overnight ? <-- means you have a leak |
