Problem with suspension
Old Oct 15, 2014 | 06:43 AM
aspen79's Avatar
Just my experience.......In most cases a burned out relay is CAUSED by an outside source, such as the compressor failing. Same as a blown fuse, 99% of the time it is not the fuse that failed but a short to ground in the circuit or the device is failing and drawing too much current.
Old Nov 8, 2014 | 09:52 AM
schiu's Avatar
My A8 D3 front suspensions compressor and valves were changed two years ago due to a leak . Recently I notice the green suspension light on the dashboard lit up for a few seconds and disappear. This usually happens when the car is stationary and the car is on comfort setting. The car was service four months ago and the mechanics said the suspensions are fine as their ross tech software shows no fault. Other than that the rest of the suspension function correctly. Is this a sign of a leak or just normal
Old Nov 8, 2014 | 04:29 PM
snapdragon's Avatar
Mine has always done this so assume normal. I think it's just warning "I'm going down - don't drive over a hump right now"
Old Nov 18, 2015 | 10:40 PM
Alberto Mayer's Avatar
Did you fix this problem I am having the same issue. Plus I changed my tires and now the car stayed down low I mean low. What can I do
Old Feb 8, 2016 | 10:37 AM
romantapia12's Avatar
Default Hellppppp !!
I have a 06 Audi a8L, yesterday my front end was low to the ground. Yes I have the blinking green light and other warning light. Need to know what it could be and easiest way to go about it.
Mickwal
Dec 22, 2016 04:54 PM
macpyro2
May 12, 2009 07:57 PM
zarko9
Jul 9, 2008 07:05 AM
ARIaudiS4
Apr 20, 2008 09:01 PM
andrew.bator
Feb 5, 2008 10:53 AM
