Removing Front Brake Calipers
Hey Guy's
I'm trying to remove the front brake calipers on a 2000 A8 Qauttro, i used a T45 tourk reach for the rear calipers but that wont work on the front one's. Any help would be great, thanks guy's |
RE: Removing Front Brake Calipers
Well I'm not supprised it's hard seeing as how it is a 2000. On my 97 I think the stock calipers were still on the car. I had to use a 5 ft breaker bar with all my weight jumping on it just to break the drivers side loose. Once they broke loose it was as simple as a normal break job. Good luck.
This link should help you. This site tells you all the tools and tricks. Helped me on a bunch of stuff I wouldn't have known being a noob to AUDI myslef.
http://www.audipages.com/Tech_Articl...rakestwin.html |
well i dont think its a torx bolt. its a 12 point star socket you need, but i forgot what size it is.
| All times are GMT -4. The time now is 01:43 AM. |
