sunroof drains?
Hi, I have a 99 A8 4.2 which has been a good car except for the damn water issues. I routinely wet vac out the area under the air intake after a heavy rain. Seriouslythinkingof installing a bilge pump. Imagine, get in the car, flick a switch, drain the compartment. No more footbath.
Anyway, today my issue is different. My driver's side rear floor is soaking wet and has been for a couple of weeks. I wet vac it up, and after rain it's soaked again. I checked my sunroof drains (the ones I can see at the front corners, and they blew out fine. Are there other drains in the rear that can't be reached? If so, does anyone know the anatomy of this car to tell me where they are or where they would come out? I found the front ones in the door pillars, but none such in the reat. Also, sometimes when I open that door after a rain, water comes out of the bottom of the door. Any help MUCH appreciated. Nigel |
RE: sunroof drains?
send aPM to one, or ALL of these three:
dankhound rayveedub avant80@2.6 One or two of them should be able to give you the answer you need... |
RE: sunroof drains?
Thanks, I'll give those a try.
