Sunroof Moonroof Summer Package
expresses my AudiForum experience!
My roof has the solar panels built in.
Does this mean I can not slide the interior panel out os the way leaving the glass in the closed position and look out through the glass?
So far, it appears as if I can tilt the trailing edge up or slide the entire sun/moon roof (interior panel and glass) backward inside the car's roof.
RE: Sunroof Moonroof Summer Package
Thats exactly what that means but in the summer your car will be cooler because the solar panel will power the blower motor and keep air circulating thru the interior and thus keeping it cooler inside.
Hey Dankhound,
Is there anyway that you can test that this actually works? It's one of those things that you don't see working you know what I mean?
I've had my A8 with moonroof for over a year and not thought that it's functioned this way once.
Cheers!
Cheers!
ORIGINAL: smartyhk
Hey Dankhound,
Cheers!
Hey Dankhound,
Cheers!
ORIGINAL: Hot Wheels
Will the solar sunroof in a 2004 A8L also function as a moonroof, or it only a sunroof like the earlier models?
Thanks
Thanks
Dank.
My 01 Allroad has the warm weather package as well. However, it has recently stopped working (the interior fams do not operate when parked) and not the interior is uncomfortably hot after being parked for a few hours.
The solar panel was not damaged, windows are all closed, and the fuse is not blown.
No one, not even two Audi dealers in San Diego, have ever heard of a problem with the WWP.
Any suggestions, before I spend $150 for the dealer diagnosis?
