sunroof question
sunroof question
just got an 05. when the sunroof opens all initally appears normal, but at the end of the opening when the deflector goes up the motor makes a rather loud grinding noise. the non audi dealer from whom the car was purchased, when asked about it, advised that this was "normal". any comments?
He probably said "normal" because it may be a common problem on D3 A8's. On D3's there is a seperate motor for the deflector, which some have had a problem with:
https://www.audiforums.com/forum/sho...wind+deflector
Take it back and demand that they replace it, if there was deal to have everything working correctly.....NOT normal!
D2's have the deflector that pops up with tiny spring pistons...works well unless little cushion pads on front of deflector stick to the body and allow the deflector to pop up suddenly after roof is fully open, instead of gradual open at start of slide-open. This leads to eventually breaking one or both of limit stops on the outer ends of the deflector...if both sides go, off flies the deflector
i only had occasion to use the sunroof yesterday, on the 05s' the motorized defector is not just to engage the deflector. it changes the angle of the deflector depending on the speed of the car to optimize it's effectiveness. just wanted ya'll to know.
