AudiForums.com
-   Audi A8 (https://www.audiforums.com/forum/audi-a8-10/)
-   -   What is steel and what is alu on A8? (https://www.audiforums.com/forum/audi-a8-10/what-steel-what-alu-a8-199139/)
Timon Aug 30, 2013 09:20 AM
Considering buying one of the first versions of the A8 from the 90's or 00's. How much of the car is made of aluminium? And what can I expect to rust?
josh A8 Sep 14, 2013 07:43 PM
the things that will rust, especially in the northeast road salt are:
transmission lines
power steering lines
K frames
fuel and brake lines
the rest of the car is aluminum. aluminum can corrode, but from what I've seen it's not significant.
you can see the power steering lines behind the driver front wheel
the transmission lines will rust near the radiator
the K frames connect the driver side and passenger side lower suspension together. I've not seen a rusted out K frame but it could happen.
watch for broken springs too.
josh A8 Jun 25, 2015 08:47 PM
correction - brake and fuel lines are aluminum
the brake and fuel lines I took off my 1999 A8 parts car are aluminum
