Who's interested in an A8 timing service DIY?
Glad it all went smoothly for you, I was not so lucky with mine. I marked all the cogs and the belt and put it all back together accordingly, and everything runs great, except I have a check engine light due to cam timing faults, so I guess the job isn't totally idiot proof.
Shortly after doing that I replaced my valve cover gaskets and was hoping to check the timing marks on the camshaft, but believe it or not (I probably would have trouble believing it if it came from someone else) there were no timing marks on my camshafts!
I still haven't decided what I'm going to do about it, it's Winter in the midwest and I have no garage so working on it myself can wait, I also have less money through the Winter months so if I am going to take it to a mechanic that will have to wait too.
cam marks
are you sure there are no marks? One is on the bearing cap and the other is on the sprocket part of the camshaft.
Both markings are under the valve cover, neither is visible with it installed. If the engine is at TDC you should see them.
Here's a short video I posted on youtube on what I removed doing the timing belt. Fuel pump replacement is posted as well.
http://www.youtube.com/watch?v=MniODl1kLYA
Bob
Bob
Bob
Bob
Great video A8CT! You have had quite the collection of A8s!
That is interesting Auditech, I have the triangle marks on the bearing block, and according to my manual there should be corresponding marks on the (can't remember if it was the camshaft itself or the sprocket, it was a couple of months ago that I went through this).
So the question now is, if I take it to an Audi mechanic to have the timing fixed, how will they do it without any marks, and should I grab my ankles and back up for it?
#18
Any audi mechanic can do a timing belt change with his eyes closed, the fastest i did an A8 timing belt job was about 50 minutes......it leaked coolant but thats besides the point LOL!
#19
Here is a link to the factory sprocket gear puller we use. http://www.amazon.com/VW-Audi-Cam-Sp.../dp/B000RT89YS I almost never do a audi/vw V motor without one, its a pain in the *** to get the belt tensioned correctly without one.
#20
cam marks
ok, so you see the triangle marks on the bearing cap that's good. If you look right behind the cam sprocket (that connects via the chain to the other cam)....you'll see a tiny rectangle stamped behind the sprocket on the cam itself. Lining up these two marks means your cams are where they need to be.
There aren't any marks on the "main" cam sprocket (not keyed as auditech says) or on the part of the camshaft that extends beyond the tensioner.
Auditech, are these marks only on the 4.2's? I have an extra head and some camshafts on the bench along with my old tensioner. I was going to shoot another youtube video so people could get an idea on cam tensioner and/or gasket replacement.
You'll be able to see them clearly then, maybe I'll do that later tonight if I have time.
thanks for the compliment on the video, I got one of those $100 pocket camcorders in a raffle and never thought I'd use it. It's a great tool to have around the garage, I'm using it all the time now.
Bob
Bob
