Why do I have to lock the steering?
I still don't have the manual from the dealer so I'm not sure if this is in there.
When I turn off the car I get a message that says hold off to lock the steering. Why doesn't it do that automatically when I turn off the car? Is there any reason I wouldn't want that? Thanks. |
Anybody?
Never seen that before, it should lock itself the second you remove the key. Is it not locking the steering after removing the key?
Originally Posted by auditech79
(Post 1185842)
Almost positive it is just a warning message saying to either do it or that it does it automatically. It shows that every time I turn off the car as well. Using the push button start as well. Don't worry about it lol :) Just let the car do it's thing.
Well, when I do hold the button like it says there's a loud click as the lock is engaged. So, I'm not sure if anything actually happens if I don't do it....
nothing will happen if you don't do it. See if you don't do it and you get in your car the next time you drive it if you can turn the wheel. I never touch anything when I turn the car off, and when I get to get into the car the steering wheels always locked. If your that concerned about it I bet just call-up your local Audi dealer and ask them over the phone they should answer it lickety split
Originally Posted by Brozee
(Post 1185969)
Oh yeah i forgot about the push button start, if you are using the push start button you need to hold down the engine off button to lock the steering.
Duh, brain fart auditech..... Try using your key to run it next time and it should automatically lock the second you remove the key. |
I eLov a happy ending!!!
