Issues with door handle touch sensor, and central locking button
Has anyone encountered the following trouble codes? How did you get it resolved?
Trouble codes: 00191 - Front passenger exterior door handle touch sensor Short circuit to ground static 00192 - Left rear exterior door handle touch sensor Short circuit to ground static 00193 - Right rear exterior door handle touch sensor Short circuit to ground static 00190 - Driver exterior door handle touch sensor Short circuit to ground static 02126 - Central locking button, exterior door handle Implausible signal static Here are the details from OBDeleven data log: Date: 2018-12-17 17:22 Car: Audi Q7 Year: 2009 Body type: SUV Engine: BHK_ 206 kW (280 HP) 3.6 l Mileage: 88050 KM --------------------------------------------------------------- 05 Kessy System description: FBSAUDIC6 ELV H05 Software number: 4F0910852B Software version: 0100 Hardware number: 4F0905852D Hardware version: 242 Serial number: 10602601197986 Coding: 0000135 Subsystems: System description: FBSAUDIC6 EZS H03 Software number: 4F0910132L Software version: 0020 System description: FBSAUDIC6 KSG H03 Software number: 4F0910335B Software version: 0020 System description: FBSAUDIC6 IDG H01 Software number: 4F0910220G Software version: 0040 Trouble codes: 00191 - Front passenger exterior door handle touch sensor Short circuit to ground static 00192 - Left rear exterior door handle touch sensor Short circuit to ground static 00193 - Right rear exterior door handle touch sensor Short circuit to ground static 00190 - Driver exterior door handle touch sensor Short circuit to ground static --------------------------------------------------------------- 52 Door Electronics Passenger Side System description: TSG BF Software number: 4F0959792R Software version: 0250 Hardware number: 8K0959792D Hardware version: H11 Serial number: 0000100286684 Long coding: 010D57205E40440004 Trouble codes: 02126 - Central locking button, exterior door handle Implausible signal static Thanks! |
Update
Originally Posted by jcalora
(Post 1521578)
Trouble codes: 00191 - Front passenger exterior door handle touch sensor Short circuit to ground static 00192 - Left rear exterior door handle touch sensor Short circuit to ground static 00193 - Right rear exterior door handle touch sensor Short circuit to ground static 00190 - Driver exterior door handle touch sensor Short circuit to ground static 02126 - Central locking button, exterior door handle Implausible signal static Here are the details from OBDeleven data log: Date: 2018-12-17 17:22 Car: Audi Q7 Year: 2009 Body type: SUV Engine: BHK_ 206 kW (280 HP) 3.6 l Mileage: 88050 KM --------------------------------------------------------------- 05 Kessy System description: FBSAUDIC6 ELV H05 Software number: 4F0910852B Software version: 0100 Hardware number: 4F0905852D Hardware version: 242 Serial number: 10602601197986 Coding: 0000135 Subsystems: System description: FBSAUDIC6 EZS H03 Software number: 4F0910132L Software version: 0020 System description: FBSAUDIC6 KSG H03 Software number: 4F0910335B Software version: 0020 System description: FBSAUDIC6 IDG H01 Software number: 4F0910220G Software version: 0040 Trouble codes: 00191 - Front passenger exterior door handle touch sensor Short circuit to ground static 00192 - Left rear exterior door handle touch sensor Short circuit to ground static 00193 - Right rear exterior door handle touch sensor Short circuit to ground static 00190 - Driver exterior door handle touch sensor Short circuit to ground static --------------------------------------------------------------- 52 Door Electronics Passenger Side System description: TSG BF Software number: 4F0959792R Software version: 0250 Hardware number: 8K0959792D Hardware version: H11 Serial number: 0000100286684 Long coding: 010D57205E40440004 Trouble codes: 02126 - Central locking button, exterior door handle Implausible signal static Thanks! Hey mate have you had any joy in finding out what your issue was as I've just picked up a Q7 saying the same thing🤷🏿♂️ |
| All times are GMT -4. The time now is 03:15 AM. |
