SQ5 Alive! Introducing the AWE Tuning SQ5 Touring Edition Exhaust with 180 Technology
Perfect part throttle civility when you need it, a disobedient soundtrack when you want it.
Highlights:
An exhaust for the 8 speed Tiptronic: Solved.
Since there is no independent control of the valves (except “Sport” mode which changes a number of other things), the AWE Tuning 180 Technology™ equipped exhaust responds to driver inputs seamlessly, removing the need for valving.
180 Technology™ is not the standard, typical approach to performance exhaust design. Through proprietary mathematical calculations, AWE Tuning engineers were able to create a sound cancellation resonator that definitively “turns off” the frequency where drone occurs. At the same time, while being able to squelch drone 100%, the resonator design is also providing a 100% straight through, full diameter flow for maximum performance. So at part throttle, relaxed driving: zero drone. At full throttle, attack mode: straight up aggression (all with no power compromises). Just like a valved system.
The detail behind 180 Technology™ is here.
Cancel it out: AWE Tuning Electronic Valve Simulators
Sound perfection comes standard thanks to AWE Tuning 180 Technology™. Which means there’s no need for valves. But when these valves are eliminated, the ECU stores what is known as a ‘soft code’ in the system. While this code is not harmful, who wants it? Enter the AWE Tuning Electronic Valve Simulators.
These simple devices plug right into the factory harness in place of the exhaust valves, and prevent any code from ever being stored in the ECU due to the removal of the exhaust valves. Plug them in. Start it up. Drive away. That simple. Comes as a set of two.
What’s in the box?
The SQ5 Touring Edition Exhaust includes the exhaust system itself, four exhaust tips, valve connector block offs (in case you don’t opt for the valve simulators) and all clamps and hardware required.
More in the AWE Tuning SQ5 Touring Edition Exhaust section of AWE-Tuning.com.
Highlights:
- Featuring AWE Tuning’s sound cancellation solution: 180 Technology™
- Engineered around the SQ5’s specific Tiptronic tuning
- Direct bolt-on
- X-Pipe for enhanced exhaust scavenging and improved tone
- Available with Chrome Silver or Diamond Black adjustable quad outlet 102mm tips
- Crafted from 2.5” T304 Stainless Steel
- No CEL Guarantee
- Fitment Guarantee
- Lifetime Exhaust Warranty
What’s in the box?
Andrew/AWE
Audi Q5
Dec 16, 2014 04:44 PM
Andrew/AWE
Audi Q5
Dec 15, 2014 12:38 PM
Andrew/AWE
Dec 1, 2014 05:36 PM
Andrew/AWE
Jan 24, 2014 11:24 AM
Andrew/AWE
Aug 14, 2012 10:52 AM
