2017 Q7 Factory Towing Package Not Compatible w/Weight Distrubtion Hitches
#51
https://www.etrailer.com/p-C40035.html
I'll then either use the sway ball bracket or have a sway ball tab mount welded to the ball mount. (https://www.etrailer.com/Accessories-and-Parts/Draw-Tite/3442.html)
Thanks!
Thanks!
#52
2017 Q7 Factory Towing Package - 12V Charging to Trailer Battery
I just wanted to follow-up on my previous posts trying to understand why my 2017 Q7 with factory towing package wasn't providing 12V power to my trailer through the 7 pin socket. Problem resolved thanks to a visit to Audi Stratham in Stratham, NH. They were very professional and quickly resolved the issue.
See attached photo from the Audi manual: In the left side of the rear luggage compartment is a fuse bank. In row B, fuse number 9 provides 12V to the trailer 7 pin socket --- my fuse was blown. Once the fuse was replaced, everything worked perfectly.
I suspect the fuse blew during my extended travels when I was running my 12V trailer refrigerator while towing. Not sure how many amps it draws, I will have to look into this.
I misinterpreted the Audi manual: I was focused on fuse slot number 7, which was empty, no fuse was provided from the factory. Audi Stratham explained this fuse slot is not used in the U.S. market and that's why the slot is empty. I mistakenly thought I was not getting 12V power to the trailer because this fuse was missing. Okay, don't laugh too hard. Everything works now, but thought I would share this in case anybody else is trying to resolve 12V power to their trailer.
#53
The Q7 I just purchased does not have air suspension as I did not miss it on the Touareg.
BTW, Etrailer.com is a great resource for towing accessories. There is an #8000 lb aluminimum ball mount available that is within a 1/4" of the length required by Audi. Here's the link: https://www.etrailer.com/Ball-Mounts...en/AM3503.html
#54
Thanks for your posting, it all makes sense!
Question - Did you ever use weight distribution on your Touareg's? If so, what advice can you offer? My Q7 does not have air suspension, and I would prefer to use W/D but I'm afraid to do so because of the sternly worded warning in the owner's manual.
#55
#56
Great, thanks for sharing your experience. I have a relatively lightweight 20' R-Pod Trailer approx. 3,500 lb. loaded. My Q7 (steel suspension) droops roughly an inch when hitched up. It tows great, like you say, better than my 2013 Ford F-150. The only reason I'm asking about weight distribution is to possibly level out the droop in the rear suspension, but I agree with you.....Audi makes it clear not to use W/D and it handles very well without it.
#57
#58
Q7 on Audi Facebook with Weight Distribution
Hi All,
I have a 2017 Audi Q7 Prestige with the Air Suspension. It tows amazingly! I'm connected with Audi on Facebook and they recently posted the attached picture with a Q7 towing with Weight Distribution. I've also contacted Can Am RV in Canada and they assured me that there is no issue using WD with the Q7. Anybody using WD with the Q7?
#59
New hear... I'm considering buying a 2018 Q7 and plan on towing our trailer with it. It's a 3200lb dry (3800lb loaded, 400-450lb tounge) single axle trailer. We have been towing it with our 2009 Acura MDX. Although MDX manual does NOT recommend using a WD hitch I have installed one and towed with it without any problems. My understanding was the reason against using a WD hitch was it might interfere with vehicle stability control system.
I am glad to find this thread and reading through it it seems that Q7 too advises against using a WD, as I was planning to use a WD.
So I suppose I should forgo using the WD on Q7. The issue of using a very short ball mount (with a 2" ball) is concerning as my trailer needs a 2 5/16" ball and it seems I might need to raise the ball or the trailer will sag considerably at the front.
Am I really limited to use the Audi ball mount or can one use a standard ball mount with 2 5/16" ball?
#60
They have 1" shank rise ***** as well...
My trailer is quite a bit bigger than yours and it towed very nicely without a WHD... BUT I have the adaptive air suspension which I highly recommend. Also, even though mine is a tandem axle trailer which tows well, I did add a sway controller since I was not using a WDH and we get some pretty high winds in UT. An appropriate tongue weight (relative to trailer weight) is the most important factor in reducing sway, but figured an extra sway controller couldn't hurt!
