08 Q7 Tire Noise only on Right turns
2008 Q7 is smooth ( no steering wheel shake) going straight down the highway or turning to the left, but when you turn it to the right everything is still smooth, but the right front tire starts making lots of noise.
alignment done.. everything in spec.
new Blizaks on Q7. 20" tires ( I even rotated them)
Made the same noise in the summer with summer only tires on, and the outer edge of the tire wore off pretty good (typical)
I put it up in the air and everything is tight, cant' feel any wheel bearing play.
Both sides has about 1/8" up and down movement in lower ball joints
Could it be the right side drive shaft? wheel bearing?
140,000 miles
Still noisy
Thanks in advance,
Greg
140,000 miles
Still noisy
Thanks in advance,
Greg
marcb0127t
04-07-2012 02:09 PM
quattros4life03
09-06-2008 04:21 PM
