Water on floor 2013 Q7
Hello.
I have a 2013 Q7 S line. I have read posts on here for 3 days before asking this question.
I have water on both the driver and passenger sides floor. I found the AC condenser drain in the passenger side and it was in fact plugged. Pulled the rubber hose off and drained it. Then used a flex tube to clean out the rubber hose, and once the blockage cleared, water poured out of the hose. So this answers where the water was coming from in the passenger side. But what about he driver side? I took the upper kick panel off above the pedals and cannot see anything that is producing water. Not even a water trail.
Am I correct in what I read about the sun roof tube problem being fixed since 2007 model year? That shouldn't be causing this issue, right? So the only other thing I can think of is AC condensor causing it. Any help would be appreciated.
sincererawkus
09-11-2013 01:52 PM
