** GruvenParts.com Billet Head Flanges (NOT CAST!) -- Choose Your Configuration !
http://cdn1.bigcommerce.com/n-ww20x/...0.1280.jpg?c=2
Billet VW/Audi 1.8T Billet Coolant Head Flanges -- NOW IN STOCK ! GruvenParts.com is happy to release these VW/Audi Billet 1.8T Coolant Head Flanges made from 6061-T651 aluminum and professionally tig welded and 100% pressure tested. This billet aluminum version replaces the crack prone plastic 1.8T head coolant flange P/N 06A-121-132-AP, and is also interchangeable with 06A-121-133-BB, 06A-121-133-J, 06A-121-132-D, 06A-121-132-G, 06A-121-132-Q. (06A121132AP, 06A121133BB, 06A121133J, 06A121132D, 06A121132G, 06A121132Q). This part fits all 2000-2006 Audi TT w/1.8T engine and all 2000-2007 VW Golf/Jetta/337/20AE/GLI with 1.8T engine. THESE ARE NOT WEAK, POROUS CHINESE CASTINGS ! THESE ARE HOGGED OUT FROM WROUGHT AEROSPACE GRADE 6061-T651 BLOCK !! This part is machined in house like everything else we make (not in China) using one of our 4 axis CNC HAAS milling centers. This part ships with a new Viton base O-ring preinstalled. Just add your coolant temp sensor and bolt it up! We're so sure this will eliminate your crack prone head flange, this part comes with a LIFETIME WARRANTY. Options for this part include deleting the heater core outlet, oil cooler outlet, or both. And dont forget to also check out our popular billet 1.8T upper radiator hose 4Y and the billet 3Y. http://cdn1.bigcommerce.com/n-ww20x/....1280.1280.jpg Billet 1.8T / 1.9TDI / 2.0 Upper Radiator Hose 4Y! GruvenParts.com is proud to announce the release of our new BILLET VW/Audi 1.8T / 1.9T / 2.0 Upper Radiator Hose 4Y Pipe to replace the OEM Audi/VW plastic 4Y P/N 1J0-121-087C (1J0121087C) This part is found in OEM upper radiator hose P/N’s 1J0-122-101BL (1J0122101BL), 1J0-122-101R (1J0122101R), 1J0-122-101A (1J0122101A), 1J0-122-101B (1J0122101B), 8NO-122-101A (8NO122101A), 8N0-122-101B (8NO122101B) http://cdn1.bigcommerce.com/n-ww20x/....1280.1280.JPG GruvenParts.com VW Golf/Jetta and Audi TT 1.8T Coolant Fitting P/N 1J0-122-109AQ GruvenParts.com is pleased to announce the release of our MKIV VW Golf/Jetta 1.8T and Audi TT MK1 1.8T Billet Y Pipe made from aircraft grade stainless steel to replace the cheap plastic OEM fitting found on hose P/N 1J0-122-109AQ (1J0122109AQ). |
GruvenParts.com builds bulletproof Hardware for your VW/Audi !!
http://cdn1.bigcommerce.com/n-ww20x/...de7__78572.png Click Here to Visit GruvenParts.com ! |
"Introducing the GruvenParts.com Upgraded MKIV VR6 Intake Manifold Trifecta -- A SURE Bet !
These parts replace the cheap plastic parts associated with the following intake manifold drive units - 021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon 022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon 022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos http://cdn1.bigcommerce.com/n-ww20x/....1280.1280.jpg MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines - Click the Pic ! Unbeatable Tite-Loc bushings are made to precisely mate with your intake manifold and prevent rattles and expensive damage to the manifold bore. Replace the cheap VW/Audi rod bushings with these BEFORE rattling begins to save your upper intake manifold ! http://cdn1.bigcommerce.com/n-ww20x/...0.1280.jpg?c=2 MKIV VR6 Intake Manifold Drive Ball - All VR6 Engines - Click the Pic ! A 6061-T651 billet version of the flimsy plastic drive ball which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than the lifetime billet version ! http://cdn1.bigcommerce.com/n-ww20x/...0.1280.jpg?c=2 MKIV VR6 Intake Manifold Drive Linkage - All VR6 Engines - Click the Pic ! A 6061-T651 billet version of the flimsy plastic drive link which is crucial to your VR6 variable intake manifold system. Don't spend more on a plastic part than our lifetime billet version !" |
"http://cdn1.bigcommerce.com/n-ww20x/....1280.1280.jpg
MK4 R32 / MK1 Audi TT Stainless High Flow Cat Pipes ! GruvenParts.com is proud to release this 304 Stainless high flow cat pipe for the VW MKIV R32 and MK1 Audi TT with the 3.2L VR6 motor. This high flow cat pipe comes ready to install and bolts directly to the OEM down pipe. This pipe increases torque and horsepower in the mid and high range of the powerband by eliminating the restrictive factory cat pipe. This part is intended to replace OEM P/N 1J1-131-701-JX (1J1131701JX). This pipe is precision mandrel bent from T304L stainless steel so it has no crimps and will not rust. The twin pipes are 2"" diameter and are merged with a 2.5"" single outflow pipe with smooth transitions for free flowing exhaust pulses. This pipe comes as shown with 2 brand new Magnaflow cats , 2 OEM gaskets, and all installation hardware. And, its made right here in the USA ! This pipe fits all Audi TT MK1 w/3.2L VR6 motor as well as VW MKIV R32 This part is intended to replace OEM P/N 1J1-131-701-JX (1J1131701JX). " |
VR6 Billet Aux Water Pump Bracket – All VR6 This part replaces the useless rubber donut OEM P/N 035-959-209E (035959209E) that does a poor job supporting your PRICEY auxiliary water pump, and related PRICEY hoses. The OEM rubber donut allows the weight of the pump and hoses to sag, causing stress which can lead to pump and hose failure. Our billet version is the way VW should of designed it to begin with and locks the pump and hoses tight! On or off track, this part will secure the aux pump and prevent pump and hose failure. Replaces OEM P/N 035-959-209E (035959209E) common to the following vehicles - Corrado - all VR6 Eos - 2007 + 3.2L VR6 Eurovan - All VR6 R32 - 2004 Golf, Jetta, Jetta Wagon - 1993-2007 All VR6 Passat - 1992-2005 - All VR6 and V8 Phaeton - 2004-2007 6L V12 Touareg - 2003 on 3.2L VR6 " |
"http://cdn1.bigcommerce.com/n-ww20x/...0.1280.JPG?c=2
GruvenParts Billet R32/TT Adjustable Rear Swaybar Endlinks ! Got a lowered TT MK1 or R32 MKIV ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the sway bar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the sway bar end links but GruvenParts.com has you covered! We’re proud to release these adjustable rear stabilizer bar end links with FORGED high strength steel lower bushing ends with rolled (not cut!) threads, and high strength fully sealed upper tie rod ends. The center bodies are custom machined from STAINLESS hex in house and then powder coated beautiful gloss black or Bilstein jazz blue to match our Adjustable Rear Control Arms and our Adjustable Front Sway Bar End Links. These come ready to install and are pre-greased with special polyurethane grease and include a new lock nut on the top joint. Please re-use your existing lower OEM bolt when installing these adjustable units. These are sold in sets of 2, enough for 1 vehicle. This product fits Audi TT (2001-2006), Audi A3/S3, VW MKIV R32 (2004), Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0505466B. Save Big $ when buying these in conjunction with our Adjustable Rear Control Arms and our Adjustable Front Swaybar End Links " |
