01 tt auto drop on window not working.
last week i noticed that the auto window drop was not working on the pas. side of my tt.has anyone had this problem?the window works fine otherwise.
RE: 01 tt auto drop on window not working.
I have a problem with mine not going UP sometimes. Usually when it's 90+ degrees out and the rubber sticks to the glass causing the sensor to think something's obstructing it.
Yours don't go DOWN? |
yea i did..did you disconnect your bat recently? if you did then go ahead and disconnect it again...then go put your window all the way down, then all they way up..holding the window down all the way and the same with the up..it resets the auto window down feature.
