1.8 tt need intake any suggestions?
Check the FAQ at the top of this forum. It covers the typical intakes. There rae not alot, but there are several options, from retaining the stock airbox with a k&n drop in panel filter, to an open element such as the cone or mushroom shape, to supposed cai's, custom fabs, and like a 300 dollar carbon filter job. no real gains of one or the other. do you have a 225, 180, 3.2? year?
FWIW, I had a K&N drop in filter on my stock box and noticed a pretty good difference in the ol' butt-dyno.
However, I've recently swapped out the stock airbox for a open element cone filter just because I wanted to hear my DV better. They both cost about the same and give you about the same performance increase.
^ you should get a modshack VTDA!
those things are a bit pricey but they're toootally worth it. they totally enclose and decrease airflow from the nasa-like space tube design with state of the art heat wrapping and you can also add a custom color to your intake! this is the intake to get!!
http://www.modshack.info/VTDA.htm
and don't forget the **** (stage 2) and Boost Machine (stage 3). you're going to need a 4-bar FPR w/ the ****. at modshack stage 3, your TT's gonna fly!!
^ yes. make sure you notify steve whether you have a 180 or a 225, but either or a little stretching of silicone tubing wont hurt.
don't forget the **** and boost machine, total necessities when getting the vtda. infact, every TT should have a modshack stage 3!
srcsm ftw?
srcsm ftw?
haha dont listen to clipse.
i have a cone filter (which was the vtda but i took it apart and just use the filter on the inside) which works well
shroom filters also have had there moment here, i know there is a big thread about shroom filters floatin around here somewhere.
your stock box, however, is just fine, a drop in k&n works and you could always swiss cheese the bottom
