3in DP Tips?
2 Attachment(s)
I received a 3in Ebay DP for Christmas. I also had my wife purchase the appropriate gaskets and test pipe from 42DD.
Now that I have everything ready its time to install it. I have a few questions first though: 180FWD 1. Does the EBay DP serve as both the DP and Test Pipe or was it a good idea for me to purchase 42DD test pipe? 2. Gaskets vs No Gaskets? 3. I know the install procedure is pretty straight forward but are there any tools that essentially make this easier than normal? Anything you wished you had during your install that you know would have helped? Attachment 61489 Attachment 61490 |
RE: 3in DP Tips?
1. Does the EBay DP serve as both the DP and Test Pipe or was it a good idea for me to purchase 42DD test pipe? That second peice is a test pipe. The 42dd peice is nice since it keeps it at 3" instead of going down to stock diam. But it does look however you are missing a peice if thats everything. There should be a 4" section with a 3 hole flange on it to fit w/e diam catback you have. 2. Gaskets vs No Gaskets? No gaskets. Remove all the bits of the old ones 3. I know the install procedure is pretty straight forward but are there any tools that essentially make this easier than normal? 17mm deep socket, PB Blaster (1hour set time), med and large socket, o2 socket, and new exhaust sleeve since mine rusted and broke Anything you wished you had during your install that you know would have helped? Just take your time |
RE: 3in DP Tips?
Pretty sure I have everything.
RE: 3in DP Tips?
So you have this small peice with the post o2 sensor in 2.5" for your catback (borla?)
http://www.42draftdesigns.com/images...c_mk418tdp.jpg |
RE: 3in DP Tips?
1 Attachment(s)
I'm not rocking a catback.
I'm going to connect A to B and clamp to stock exhaust. I'm hoping custom 3in catback ASAP so I'll probably keep the 42DD test pipe. Attachment 61488 |
RE: 3in DP Tips?
ok, then you are fine. When you get a catback, then get that piece to connect the TP to the catback.
