8000k HID BULBS INSTALL?
since the bulbs are xenon, i assume i can just upgrade the bulbs to a bluer color such as 8000k. is it easy to swap out the light bulbs or the bumper must be dropped? i havent picked up the car yet so i dont know? thanks
RE: 8000k HID BULBS INSTALL?
I'm pretty sure you can change them from inside the engine bay. I dont know if they are compatible or not.
Is this too bright? Wouldn't it melt your housing?
I thought xenons rancooler so it wouldnt melt your housing. I'd go 10k if you could, they look sweet!
The 8000k will be less luminous than the stock lights. 6000k is the brightest/cleanest. Also, heat shouldnt change, its the differnt kelvin level that determines the color
Servicing headlights - Gas-discharge headlights[/align]Exploded view[/align]Note: If measures are taken which could affect headlight setting, headlights are to be re-adjusted. 1. Headlight housing ◆As of approx. 04.00, igniter for gas-discharge lamp -J343 (left) or -J344 (right) is attached directly to headlight housing [/ul] 2. Fog light bulb ◆H3 - 12 V, 55 W ◆Bulb replacement [/ul][/ul] 3. Side light bulb ◆H6 - 12 V, 6 W ◆Bulb replacement [/ul] 4. Main beam bulb ◆H7 - 12 V, 55 W ◆Bulb replacement [/ul] 5. Bulb holder ◆For main beam ◆With holder for side light bulb [/ul] 6. Housing cover ◆With seal ◆For fog light [/ul] 7. Housing cover ◆With seal ◆For main and dipped beam [/ul][/ul] 8. Bulb holder 9. Turn signal indicator bulb ◆H12 - 12 V, 21 W ◆Bulb replacement [/ul] 10. Retaining ring ◆For gas-discharge lamp [/ul] 11. Gas-discharge lamp ◆35 W, D2S ◆Bulb replacement [/ul][/ul] [IMG]local://upfiles/12092/8DA2D4601A7E4D1D9EA49E761FE68509.jpg[/IMG] |
Dave you really need to send me a copy of that sw [sm=goodidea.gif]
ORIGINAL: cincyTT Dave you really need to send me a copy of that sw [sm=goodidea.gif] |
#9 is the light in the yellow reflector
ORIGINAL: cincyTT The 8000k will be less luminous than the stock lights. 6000k is the brightest/cleanest. Also, heat shouldnt change, its the differnt kelvin level that determines the color |
