ABS light on
Old Sep 15, 2011 | 07:10 PM
kwiniarz's Avatar
Default ABS light on
I'm guessing this is the ABS sensor, how do i find out which one?
anyway to reset it and see if it comes back?
Old Sep 20, 2011 | 08:13 AM
MCPaudiTT's Avatar
Drive to AutoZone. Have them read the code. Find out what the code means.
Better yet, buy a VAGCOM and do your own diagnostics whenever something comes up.
I could be many different things. Wheel speed sensor, lateral accelerometer, longitudinal accelerometer, tone ring, hydraulic system self diagnostics, broken wire, yaw sensor, steering position sensor. Pick one or more!
Old Jan 12, 2012 | 10:47 PM
rodhotter's Avatar
had one on my 01 jetta vag-com tells you which one, works on all vw audi products free on-line updates, and a service manual good investments, oh its a 30 minute job to replace a wheel sensor, $50 on my jetta for the part
Old Jan 13, 2012 | 05:34 AM
jmarshall098's Avatar
I agree to him. It is better to have a diagnostic check before replacing the sensor. There many possible reasons as mentioned. You might end up in expensive repair without checking what went wrong.
Old Jan 13, 2012 | 03:30 PM
achTTung's Avatar
And between the diagnostic test, and replacing the sensor, try blowing the crud off it.
Sensor that reads the tone ring is magnetic, and metallic brake/road debris can stick to it and cloud the reading. Been there...
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
