audi tt my shifter does not change smoothly
Old Oct 5, 2010 | 04:47 PM
sjbjtm@yahoo.com's Avatar
Unhappy 1st and 2nd gone
i was having the same problem, i just shifted into them easily and then they kept getting rougher and harder to shift...
and now 1st and 2nd gear are gone
3rd gear shifts a little rough still.
all other gears are good, rougher than i like still
its as if they dont exist, the car shifts into it but just revs. no acceleration.
can someone please tell me what needs to be done.
synchros? shift cables? shift linkage?
please let me know what needs to be fixed. im missing school right now cause of this dilemia
2001 Audi TT quattro 225 model
Old Oct 5, 2010 | 09:12 PM
warranty225cpe's Avatar
Originally Posted by beachchair
Notchy? I don't find that at all.
The bushings make for a more precise, smoother shift with less slop.
I think so. just the fact that the material is harder (brass/rubber) Makes it a more "positive" shift. Yeah no more play, but the stops are more abrupt as a result. (get where im coming from?) In my experience, the only way to get rid of all the issues in the shifter is to cover both ends. the trans side of the linkage is only 1 weak point(source of play/issues). the shifter itself is the other end. I think the shifter tends to be a huge part of the problem in older cars with a ton of miles.
Old Oct 5, 2010 | 09:14 PM
Could be a number of things. You need to get it on a lift and check it out.
Old Jan 19, 2012 | 04:42 PM
hilfigjp's Avatar
Warranty225cpe, where did you get your front grills and how much? thanks
Old Oct 17, 2021 | 04:39 PM
musiccity365's Avatar
Default ATF in lieu of gear oil
I've been told that with some manufacturers that this issue can be resolved by replacing the manual transmission fluid with ATF. At least with BMWs this is an approved method. Does anybody know if this method is approved with VWs/Audis as well? My friend has a 2000 Audi TT 1.8T with a 5 speed manual gearbox and it's also experiencing notchey shifts. Here's the VIN if that's helpful at all...
jibberjive
Feb 24, 2009 12:57 AM
jibberjive
Jan 9, 2009 09:16 AM
AUDI05
Feb 21, 2005 08:37 PM
jaygill86
Nov 23, 2004 01:24 AM
