boost
Old Jun 1, 2008 | 09:33 PM
Audi858's Avatar
Default boost
Ok so I get my computer back on weds. For now I put my stock computer back in id tried boosting it but it didnt build. I have my 675cc seimen injectos in 3inch MAF housing, FMIC. ITS .63 A/R gernal bearing turbo.
Ok so I can hear the turbo spooling really loud but im not building PSI. I tried giving it a quick pull through 1st and 2nd and then the check engine light started flashing any ideas?
Should I be able to build some boost?
Old Jun 1, 2008 | 10:15 PM
myslow1's Avatar
Default RE: boost
one of your charge pipes isnt on at all or all the way. If you feel no power what so ever and you can hear the turbo you prob blew one off.
Old Jun 1, 2008 | 10:31 PM
Audi858's Avatar
Default RE: boost
I check but everything seemed connected and clamped good
Old Jun 2, 2008 | 01:03 PM
cincyTT's Avatar
I'm make believe
Default RE: boost
there is deff a boost leak if you can hear the turbo spool and you are not making boost. When you did the fmic, did the map fit properly? You need to try to retighten the clamps at every connection again. also what fmic did you get? If its an ebay fmic, it could have a hole leaking pressure also.
Old Jun 2, 2008 | 01:53 PM
WishIWasRWD's Avatar
Default RE: boost
Is it bad that the same stuff that made me laugh in 8th grade still does?
ORIGINAL: Audi858
I have my 675cc seimen injectos ...
Old Jun 2, 2008 | 04:25 PM
Murderface's Avatar
Default RE: boost
ORIGINAL: WishIWasRWD
ORIGINAL: Audi858
Audi titty! hehehe![&:]
Old Jun 2, 2008 | 04:31 PM
Default RE: boost
Ok good... at least i'm not the only one
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
