The boost machine/ect ect thread revisited.
Old Oct 3, 2007 | 07:49 PM
cincyTT's Avatar
I'm make believe
Default RE: who might be interested in a boost machine for NOT modshack prices?
from what size exhaust post cutout? I can see it making a big differnce if he is runningsmaller than 2.5" and with a 35r. But still, it cant be more than 15-20hp depending on the size post cat.
Old Oct 3, 2007 | 10:02 PM
rayveedub's Avatar
the difference is the boost pressure will be different. example, with the 2.5 system and its additional back pressure from the cutout system and boost controller set to say 18 psi you will spool in x amount of time and the turbo will hit however hard. now you open the dump you are now changing the flow characteristics and now the turbo spools faster, hits harder, and isboosting to 28 psi, awp rods will be bent here. yes the boost level changes with the dump tube open. we tuned donsupremes car to run at 17 psi normally and with the cutout it is hitting 26 psi. which he can handle cause i tossed in scat rods, and a bosch 033 in tank pump. he also had a unitronic (best software ever) bt 660 file with there respective injectors. this set up would be terrible for ryan. he dosent have a fraction of the hardware and based on my experience his rods are probably rusted (jk ryan....had to get you back).
Old Oct 3, 2007 | 10:06 PM
rayveedub's Avatar
oh also i didnt answer your question he has a 2.75 opening to a 3 inch. trust me we found out the difference as soon as it hit 30psi and started detonating. there is no cat in his system.
Old Oct 3, 2007 | 11:01 PM
cincyTT's Avatar
I'm make believe
ok, im on drugs for my back and they are now kicking in. So bare with me and im not trying to sound condicending or like an ***
He has a 2.75 turbo back and a 3" dump... correct? Now your telling me he gains 9psi just by opening the dump regaurdless of boost control? Thats not right. Also your talking 35r which at 19psi can bend any stock rod. So your totally losing me on this. If this is the case, what is used for boost control?
But yes, spool will be faster and more power will be made with less restriction on a 2.75 => 3" dump on a 35r, but a 2.75" is more than enough exhaust to not hinder any turbo up to a 3071r or even 3076r and going to a 3" dump will give minium gain. So im having a hard time believing your explaination
Old Oct 4, 2007 | 12:06 AM
rayveedub's Avatar
he has a crappy exhaust set up. it goes from a 3inch down pipe to the cut out section, after that it flares down to a 2.75 with a muffler on the end. believe it or not im telling you this is how it works on this car. with that dump open it is raising boost considerably. we are using a turbosmart boost controller. whenever you change a turbo's flow dynamics it changes boost pressure. you have to adjust the boost controller accordingly. manual boost controllers are passive and cannot tell the difference from turbocharger flow dynamics.
do an experiment, disconnect your catback, i guarentee you see a change in charge pressure.
also a i agree, the 35r comes on very aggressive and can bend rods, but alot of speed psychos out there take this chance daily. i know he has gone over 19 on stock bottom but rarely. now with the drop in scat rods he is constantly passing this mark with no problems. actually this same guy is setting up a drag race day at capital raceway in the audizine regional forums. i will try to get him to chyme in here. but believe me i rode with him for 3 hours to h20 and watched this in action.
Old Oct 4, 2007 | 12:10 AM
cincyTT's Avatar
I'm make believe
i seedonsupremepost on vortex all the time.
Old Oct 4, 2007 | 12:20 AM
rayveedub's Avatar
well idk if your farmiliar with his set up but this is how this car is running. and i dont see how on any car there would be no difference in boost by changing a component such as exhaust.
i swear i am not trying to sound like a *** hear i want to let you know i think you are really knowledgeable in tt or 1.8t tuning, and never usually have to post stuff hear cause you are quick to give the correct answer. but have you ever installed or personally had experience with cut outs? or highly tuned cars? I think the way you are thinking is based more or less on any car with the stock boost controller hooked up and just a off the shelf chip. most highly tuned cars are no longer running alot of sensors or dont have some of the protection features that off the shelf chip upgrades give. custom tuned software specifically from unitronic is very aggresive and usually throws alot of stuff out the door. if donsupreme's car had a MAF onit, he prolly wouldnt even have a cel.
Old Oct 4, 2007 | 12:53 AM
  #18
cincyTT's Avatar
I'm make believe
I can see it making a spoolfaster and more overall power, but boost is regulated by the pressure in the charge pipe going through vac line to the wastegate and altered by a boost controller inbetween. Im not seeing how changing the exhaust size or length of the exhaust will change how the boost is regulated. But your right, i havent delt with a cutout let alone on a highly tuned car.
Are you guys usuing a turbosmart mbc or their ebc?
Old Oct 4, 2007 | 01:18 AM
  #19
rayveedub's Avatar
its the mbc. im sure you know how a boost controller works, so know that why wouldnt it change? it being the boost of course. it is still set to to bleed out x amount of psi. so you change everything else then the mbc has to be changed.
Old Oct 4, 2007 | 01:47 AM
  #20
cincyTT's Avatar
I'm make believe
With a ball and spring mbc, the pressure needed to move the ball up to get to the other side of the mbc to then reach the wastegate takes force. So i know that wouldnt change, but a bleed/gated valve might be the problem. So im betting if you move to a ball and spring mbc (ceramic ball for faster spool) or a ebc you wouldnt have any dramtic spikes like you seem to have with a bleed valve. Plus im only a fan of bleed valves on a stock turbo, and nothing else.
from Boostvalve.com
How does it work?
In simplest terms: Itprevents boost pressure from opening the turbo's waste gate until the desired presetboost level is reached. Inside the valve is a precision stainless steel ball that is held in place by spring tension. During the turbo's spool-up (as pressure is building) spring tension in the valve is greater than the boost pressure pushing against the ball, so the ball prevents the air from flowing to the wastegate actuator.
This maximizes the efficiency of the turbo during the spool-up by using the greatest amount of air possible to spin the turbo charger. Most boost control systems waste air by venting much of the air out, even many factory boost control systems wasteavailable exhaust energy during this crucial spool-up period.Once the turbo spools up to the desired boost, the Boostvalve opens, quickly opening the waste gate. Boost pressure is held at this level with accuracy unmatched by even more expensive methods of boost control.
Alright. So, why is it better than a "bleeder"?
A bleeder valve is open all the time. Bleed valves work by fooling the waste gate into only seeing some of the boost pressure. The rest of the pressure is vented off, sometimes completely wasted by blowing out an open hose. Just like an air leak in any other hose this wasted air can cause problems with modern computerized engine controls. Additionally this causes the waste gate to open before maximum boost whichcan create turbo lag.
So again, dump the bleed and go with a ball and spring or a full ebc and im sure you wont have problems anymore
