Boost Problem (REVO?) Help!
Old Nov 9, 2005 | 12:39 AM
Tloop's Avatar
Default Boost Problem (REVO?) Help!
So I just bought a 2001 tt 225 coupe. I installed Revo software (and turned up the boost) and after having it on for about 1 week, a weird noise suddenly started coming from the front left part of the car when the car is in high boost (mostly low rpm, full throttle, in 3, 4, 5, 6 gear). It sounds like something is leaking, a deeper blowing sound sync'd with the turbo spool. The dealership replaced the diverter valve and checked the vacuum lines (or claimed to have) and can't find anything wrong.
Does anyone know what this could be?
Any help would be greatly appreciated. Thanks
Old Nov 9, 2005 | 10:37 AM
Jestnomen's Avatar
6th Gear
Default RE: Boost Problem (REVO?) Help!
Can you have someone rev the engine while you open the hood and listen? Do you have a Vag-Com to log boost pressure?
Old Nov 9, 2005 | 09:55 PM
Tloop's Avatar
A friend of mine does, but he lives far away. The dealership insists that the sounds is normal (although other similiar tt's don't make the same noise) and says it is due to the Diverter valve. I'm so confused...
Old Nov 10, 2005 | 10:21 PM
TTsteve's Avatar
The diverter might be bad too.
Old Nov 10, 2005 | 10:55 PM
Emil@RENN=ART's Avatar
did u try an aftermarket DV?
Old Nov 12, 2005 | 09:42 PM
Tloop's Avatar
yes i just installed the Forge DV, but the car still isn't performing as well as it did before the noise, and it is still there...no one can figure out what is wrong, lol...
Old Nov 14, 2005 | 12:24 PM
QuickSilver's Avatar
Sound like you might have a IC hose leaking some boost off. I had a friend witha GST Eclipse and he would blow hoses all the time. Just a Thought?
Old Nov 17, 2005 | 12:57 PM
RussTT's Avatar
Sounds to me like a boost vacume leak check all your hoses make sure their tight and have no holes or tears.
Old Nov 17, 2005 | 02:20 PM
Tloop's Avatar
The dealership ran all of the vacuum tests twice and had 4 different mechanics try to figure the damn thing out...they even said that it wasn't normal but couldn't find the leak. I will definately re-check all the things you have mentioned. thanks.
DiscoPotatoAfour
Mar 15, 2010 06:07 PM
RaFa
Dec 3, 2007 10:57 AM
pshadow
Aug 1, 2007 12:00 AM
Blown87camaro
May 4, 2007 01:39 PM
eipracing
May 11, 2005 10:26 PM
