CAMS
i am looking for cams for my audi TT 225 i found some from Eurospec Sport i want to know what duration would be sutable because i dont want to install them and the car doesnt work i foun 210 250 and 268 duration all with a 110 lobe center can anyone help out with the subject i just want to know about it so please no arguments
thanks Rich |
RE: CAMS
This link might help you it kinda explains what it does off to the right of the specs Clickhope that helps you
RE: CAMS
He's a '01 that's non-vvt.
RE: CAMS
As am I (am I missing something)?
HYDR: sport Excellent grind offering good power throughout the midrange. No VVT from that description I would think it works on non-VVT engines and is not meant for the engines with VVT |
RE: CAMS
If you are not running something making 350whp or more, you dont need cams and are wasting money. If you want cams, Cat Cams make the best. If you are planning to put these on a stock turbo, this isnt an Evo.
RE: CAMS
Cams are a big deal on N/A engines, not so worth it on forced induction until you start to run out of other mod options. But you didn't want any arguments,so have at it.
RE: CAMS
cat cams are the best option we have for 1.8t's. but there is a problem with the gears not being properly aligned to the cams. Often guys modify them and weld them, i have refused to install a set modified like this before due to crappy welding (cracks in the weld). As cincy said, cams are only needed in high tuned applications, 350 hp dosent need cams.
