Changing turn signal lever on 2001 TT
Do you have to pull the steering wheel to change the turn signal rely on a Audi 2001 TT? my cruise control has quit and I told usually its the switch and I want to know it the steering whell has to be pulled off? thanks for any assistance. Matt
cruise
I know for the cruise control there is usually a module that goes out because of the tiny cracks in the solder
Cruise control
I looked for a module, the TT ( i'm told does not have one) i look behind the glove box not one there. I was told it has a ECU or ECM? and the signal lever is probably it. so I bought one. Just wasn't sure if you have to take steering wheel off
Inside door lock red light stays on
2001 tt, doors lock from the inside do not work, the key fobs will still lock the doors. But you cant lock them from the inside switch and the red light on the switch always stays on? Any one know? Thanks
door lock switch stay lit
I have Audi TT 2001, and the door lock switch, has starting to stay lit (red) and does not work from the inside. the key FOB still works though.
Anybody ever had this issue? Thanks |
Personally I do not have such problem.. I got my car on a lease from https://dsrleasing.com/ and I am very satisfied!
I have AudiTT 2001, the inside lock switch doesn't work, light stays on the switch. locks work with thr key FOB, any ideas?
2001 tt cassette deck issue
anyone have any idea the cassette deck switches back and fourth all the time to top and bottom, or the program I think they call it. and I bought another exact TT radio cassette like my old one, will I have to have the CODE from the one I'm going to replace the old one with to get it to work? thanks
