Chicago 2 marrow for new TT
Old Apr 21, 2007 | 02:03 AM
Blown87camaro's Avatar
Default Chicago 2 marrow for new TT
Well im flying to chicago tomarrow to test drive this 2001 tt before i buy.... Any last things i should look or listen for while im driving, to make sure everything runs good? Any good way to test the traction control system make sure all is well?
Old Apr 21, 2007 | 04:27 AM
ouTTie914's Avatar
Default RE: Chicago 2 marrow for new TT
Launch it, and get out to look at the tire marks! That'll tell ya if it works!
On a serious note, tell them you want to drive some curvy roads. Get a feel for the handling with the traction control on and off.
I'm not sure of any other way to see if it works on a test drive.
Ask for service records, carfax if you haven't already. Check the tire tread and rims, be on the look out of curb rash.
As far as listening goes, well, I've come to notice that when something is wrong, the car will let you know.
Like Honking from the DV. High pitch squeal on a cold start from the secondary air pump. You'll know if something isn't right.
Look to see if any lines are missing from the LCD display.
That's really all I can think of for now. Best of luck! I hope all works out, and you have a nice drive back!
Old Apr 21, 2007 | 05:03 AM
Murderface's Avatar
Details to check, just randomly off the top of my head:
-Seat heaters, make sure both work, they tend to die.
-CD changer magazine...make sure it's there $30 if it isn't
-Hatch cover...make sure it's there...looks ugly without it IMO
-Alien washers (turn on headlights, pull wiper stalk like to spray windshield and hold it). If they don't work, it might be a coverup for a washer fluid leak...which you should also check for. If the yellow "volcano" is at the top of the LCD, the fluid's likely leaking...don't count on it just being low.
-Make sure the DV works. Get it into 5th and floor it then let off around 2,xxx RPM. If you hear a fluttery noise the DV may be toast and you're getting compressor surge. Mine came with a busted DV and I only found out 6000 miles later.
-If you think you're getting compressor surge, ask to open the airbox and rev it, or to pull the DV from the intake hose and rev it...if you hear the flutter with open intake, it's surging. If the DV doesn't blow any air out when the engine's reved...it's toast. $60 to replace, $130 to upgrade.
-Check for curb rash. It's nasty looking yet often overlooked.
-Check for any roof leaks...mine came with a leak in the hatch at the very top. Good way to do this is take a hose to it.
-Make sure all the seat adjustments work. The passenger's side reclining **** didn't work on mine, but the dealer fixed it before I got the car.
-Make sure the windows go up/down like 1/2" when you open/shut the doors. My passenger's side didn't...dealer fixed it while fixing some harness or something. But it could be a sign of electrical problems and could ruin your windows.
-Make sure you don't smell a sorta burning ceramic smell...like brake smell...that=fried clutch. I had mine replaced under warranty cuz some ******* at the dealer banged the gears to hell.
-Check and make sure all the climate control works right. All the things to aim the airflow are fiddly electrical things so it wouldn't surprise me if they broke.
-Make sure fuel cap/hatch buttons in bottom of center console work. Kinda screwed if they don't.
-Check for any burnt out bulbs, they can be a pain to replace in the front from what I hear...rear lights are simple to remove.
-Check headlight alignment. If they are misaligned it may have been in a wreck, perhaps a small one.
-Check body panel alignment all around, it's just good practice...
-Take a peek at the engine covers and screws...my screws are all messed up and my one cover's cracked. 42DD sells a metal hardware kit for $100 that I want/need badly lol
Old Apr 21, 2007 | 11:55 PM
audistud13's Avatar
dont forget to mention the timing belt to em. it need sto be replaced at 60k . i would try to have them replace it or drop the cost about a grand.. and make sure the windows all seal properly, mine had wind noise. double check the console for missing lines, dont buy it with them screwed up. hmmn what else?( thinking........................)check the undercariage for cracks, rust and stuff. i'd say spend a good hour overlooking thwe whole car. ANDMAKE SURE TO GET AN EXTENDED WARANTY!!!!. thats all, good luck and god speed.
Old Apr 22, 2007 | 03:43 AM
Hey thanks for all the replys.....heres the car btw it looked Mint and drove very nice......So its now mine should be here mon or tues there shipping it to me. Question though..... i had no clue how to turn the esp on ...maybe this is a stupid question but theres the esp button above the ac ect but am i supposed to feel a difference when i press it?? lol I pressed and unpressed and had no clue. Or when its on will and esp display show up on the dash board ?
http://www.autotrader.com/fyc/vdp.js...p;cardist=1169
Old Apr 22, 2007 | 03:51 AM
eliTTe's Avatar
looks great!
When you push the ESP button on the dash, a yellow triangle with a circle around it will light up on the RPM side of your cluster, when the light is on it means the ESP is off... the ESP will always be on when you start the car, and you'll notice if you loose grip or traction in your tires the light will flash indicating ESP had to correct the problem
Old Apr 22, 2007 | 04:03 AM
Thanks for all your help!!! Ill have to check it when i get it back here cus i didnt look to see where the esp was....If something major wasnt running right with the drivetrain regardless if i knew what lights to look for im pretty sure i would have noticed funy noises or felt something off..ill assume. BUt everything was smooth and crisp so ill just have to play with the buttons when i get it here.
Old Apr 22, 2007 | 04:23 AM
plracing's Avatar
haha, dude, that dealership is like 1 mile away from my house.. on plasant hill, and st charles.. i saw somone lookin at itmaybe 1 or 2 days ago, as i passed by w/ my black tt.. (they had a very nice silver tt too, w/ chrome rims and tinted windows.. but this was like last year.). but that's a very nice car (looks just like mine )
Old Apr 22, 2007 | 06:51 PM
Lol nice.. i shoulda caled u u coulda come test drive it for me.... i just took it out around the block to wendys (geniva st i think)to eat lunch then drove it back and i washooked....and whoever their detail guy is is bad *** cuase that car loks like it just rolled off the lot lol.... BUt i gues it should when most of there cars for sale r 360 modenas and gt2 porche's...
HeyCesar
Mar 23, 2013 01:05 PM
A5er
Jul 5, 2012 08:32 PM
Bilvo
Jul 15, 2010 01:52 AM
dans93audi90s
Sep 19, 2007 09:23 PM
SAudi
Jul 9, 2006 04:39 AM
