code po118 ???
Old Jun 16, 2008 | 01:26 PM
datdonnguyen's Avatar
Default code po118 ???
i pulled a P0118 code on my audi tt 2001 says system coolent temp does anyone now what this is? my coolent level is fine thoe??? hummm
Old Jun 16, 2008 | 01:45 PM
techbod's Avatar
Default RE: code po118 ???
you can test the sensor with a multimeter ( the lower the temp = a higher ohms reading ) test by probing pins 1 and 3, example O degrees C should show 5000 ohms so the higher the temp the lower the reading and a 100 degrees C would be around 140 ish ohms, if engine is warm ane the sensor give zero reading its the sensor and you need a new one
Old Jun 16, 2008 | 03:50 PM
what is the sensor call so i can pick it up and is it hard to replace?
Old Jun 16, 2008 | 03:55 PM
techbod's Avatar
coolant temp sensor and easy enough to replace
quick edit: lots of help here
http://images.google.co.uk/images?cl...ages&gbv=2
Old Jun 16, 2008 | 04:56 PM
thanks
Old Jun 16, 2008 | 10:17 PM
kwaskow's Avatar
Easy peasy to change.....but one bit of advice is to order the $0.52 plastic retainer clip ......I lost mine and had to run back into the dealer. Stercus accidit !
doraudia4
Oct 12, 2009 12:27 PM
newbeA6
Jan 23, 2009 08:08 PM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
wolfdog
May 31, 2006 04:48 PM
