Coil-Pack Replacement... Options?
Old Jul 10, 2007 | 10:48 PM
p1zl3's Avatar
Default Coil-Pack Replacement... Options?
Hey Everyone!
--Threw a CEL today so I popped down to my local SpeedZone(TM) and did a VAGCOM. I got these codes out of it:
-P1136: "fuel system too lean"
-Failed MAF
-Vac Leak
-Failed Ho2S
-P0304: "Misfire in cylinder 4"
-Injector Fault
-Faulty Spark Plugs/wires/coil
...So I did a MAF clean (Isopropalene) and I checked my plugs... everything seemed fine except spark-plug #4 was copper and gapped past double what the others were gapped at. I reset the gap distance on plug #4 and put it in cylinder #2, swapped coil-pack 1&4 and fired her back up...
Now she idles like crap and the RPM's bounce everywhere during a simple engine rev. I'm pretty sure it's a failed coil-pack, but what I need to know; is there a home remedy/repair for this? If not what's a good replacemet/alternative for the coil-pack, so I don't just climb back into this mess with recalled packs???
Thanx for the help!
Old Jul 11, 2007 | 12:34 PM
MeanAudiA6's Avatar
Default RE: Coil-Pack Replacement... Options?
ecstuning.com has the new ones
Old Jul 11, 2007 | 02:35 PM
theTTkid's Avatar
i second that, ecstuning is the way to go
Old Jul 11, 2007 | 05:55 PM
AudiOso's Avatar
Not a bad price on a set of four. $111.95. I wonder if that is why I get a wierd little blip in my idle every now and again? My car is a 2003 though, and I thought they solved the coil pack problems with the later cars.
Old Jul 12, 2007 | 12:06 AM
cincyTT's Avatar
I'm make believe
they still have problems with coils. The hitachis are far better than the push downs and fail far less often.
Old Jul 12, 2007 | 12:09 AM
theTTkid's Avatar
haha remember when my coilpacks went and i thought i totalled my car... haha oh god, that was a bad day... i just laugh when i look back at it now... i just put stock ones back in though
Old Jul 12, 2007 | 02:35 AM
p1zl3's Avatar
I have the Hitachis' right now. I thought they were stock... ([sm=oopssign.gif]). Well, I guess I ordered another one just in case. So the Hitachis' are the way to go, but like all Audi coil-packs, burn out pretty often? I just replaced my sparks also which needed to be done anyhow, so all-in-all it's not all that bad and I have a backup coil-pack just in case...right? [sm=smiley20.gif]
I just wish there was some sort of mod or repair method for the POS coil-packs! If they fail so often because of engine heat, why not switch to straight wires with normal spark sockets or something... I gare-runn-tee the wires would fail far less than coil-packs. The only downside would be gunk build-up down in those sockets... but with a plug of some sort that could be rectified. Hmmm...
[sm=violent053.gif]COIL-PACKS
Old Jul 12, 2007 | 03:38 AM
neur0tic's Avatar
anyone have an actual link to the coil packs?
Im doing plugs and coilpacks next week and all I found on ECS was OEM replacements.
Old Jul 12, 2007 | 09:12 AM
theTTkid's Avatar
http://www.ecstuning.com/stage/edpd/...p;engine=180HP
those are for a 180
Old Jul 12, 2007 | 10:59 AM
neur0tic's Avatar
ehh.. yea i have a 125
