Convertible Rear Power Window Belt?
I just ordered one myself, shipped it out in a few hours after the order, I will provide an update when I get to installing it. Don't worry, I promise to post a response. Give me 2 weeks at the most. Hopefully it will get here sooner.
It works great! Perfect replacement, exact match. I don't know how long it will last, but I can't see it going out any time soon. Also, if you can't remember the last time you could use the window, be sure to find some grease of some kind to help lubricate the threaded lifters. I used some di-electric grease compound and it really helped out.
Belt installed it was pretty easy, maybe 20 minutes , although it was super hot yesterday and standing in the sun was very sweaty !!!
hints - drilling out the old rivets ( 2 on each side ) - put a rag or something in underneath so all the metal shavings don't fall down all around the top. then they blow around when you drive and its annoying....
Rivets are 3/16 x 1/4 - just an fyi when you buy them
To install the Belt you have to pull the riser screw out of its little socket , wrap the belt around , then work it back in place. the riser screw just slides out and has a slotted washer to go back in place correctly.
Rivet the back facing rivets in first then the side facing ones for easier alignment.
#19
old thread i see but i can add some insight, on the VW Vortex under the Audi mk I TT section a member posted a great DIY with pics, + where to get non OE reasonable priced belt. that will be my next project since my girlfriend "whines" its too cold, the doggy + I love it!!!
#20
VWVortex.com - DIY: Wind Deflector Belt Replacement
