Diode Mod, Boost Guage, and MBC Install
Old Apr 29, 2007 | 06:58 PM
  #51
cincyTT's Avatar
I'm make believe
Default RE: Diode Mod, Boost Guage, and MBC Install
if you have a map, you should be good. Then a 4.3v 1w would be all you need.
Old May 7, 2007 | 03:04 PM
  #52
myaudi98's Avatar
yeah i want this on my 2.7..... and you can do it for me since we are in cincy right?????? lol free beer!!!!!!!!!!!!!
Old May 7, 2007 | 03:09 PM
  #53
cincyTT's Avatar
I'm make believe
Havent tried it before (dont think anyone has). If you want to be the test dummy, let me know and bring the stuff.
Old May 10, 2007 | 03:51 PM
  #54
racerhex's Avatar
Lets say I already have an APR chip upgrade....well because I do...lol. I know I need to get a boost gauge, but do i need to get a boost controller too? If so would it be benificial to just do this entire setup even though I already have the APR chip?
Old May 10, 2007 | 04:19 PM
  #55
cincyTT's Avatar
I'm make believe
not really, the only time youneed to adda diode on a chipped car is if you have problems going into limp.
Old Jul 12, 2007 | 11:55 AM
  #56
smokeU's Avatar
hey i just read the thread about the diode mod. I was wondering about your last comment about adding a diode to a car that is going into limp. if you can please advise because I have had this problem and no one seems to know why. I am starting to troubleshoot by cleaning the map and cleaning the TB but so far nothing else has worked. any advice?
thanks.
Old Jul 12, 2007 | 09:50 PM
  #57
cincyTT's Avatar
I'm make believe
some chips after 17psi have been known to throw the car into limp. it seems to be more often with the gaic x+ file. Since you have an 01 and a chip, you can try adding a 4.7v diode. It may just help you out.
but before you do any of that, i see you have a differnt n75, put the stock unit back in and try that first if you havent. Some chips dont like differnt n75's
Old Sep 3, 2007 | 02:48 PM
  #58
smkn951's Avatar
cincytt,
can't seem to find a diode for an 01 tt 225 hp.
i have an mbc, w'c after reading thru your post, i am still confused.......
when the car goes into limp mode, is this a permanent until reset or momentarily?
leaving the n75 plugged in and running the mbc from the lines, would i need to cap the n75/
what's the max boost i can run on a non chipped non diode car?
thanks
Old Sep 3, 2007 | 06:45 PM
  #59
RedTTQ's Avatar
This should be stickied.
[align=left] [/align]
Old Sep 3, 2007 | 10:25 PM
  #60
cincyTT's Avatar
I'm make believe
ORIGINAL: smkn951
cincytt,
thanks
No one has found the right diode for a 225 to use.
Limp is not perminate, it can be cured by lowering the boost and reseting the ecu (unplug the battery)
You probably should cap the n75, but i nevered did and ran fine.
i dont think you can run past 1bar without a chip on any 1.8t. And since thats where the 225 already is, you cant really up the boost without the diode or a chip.
