AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   DIY Engine Cover Hardware Write-up LOTS of pics. (https://www.audiforums.com/forum/audi-tt-7/diy-engine-cover-hardware-write-up-lots-pics-61016/)
diehlryan Apr 18, 2007 11:20 PM
So please bear (or bare?) with me on this write-up. Its my first one and I unfortunately didn't take pics as I was working through it. They were all taken after the fact.
This is for a 180TT. Obviously could be adapted to a 225.
First lets define a few things.
Engine Covers:
Coolant Cover
Battery Cover
Engine Cover
Front Covers (2 of these.)
The small L shaped engine cover was not part of this. The old 1/4 turn screws still work great.
Parts:
Part A: 7- 6mm x 20mm Cap Screw Socket (Plain Steel)
http://i131.photobucket.com/albums/p...n/100_1378.jpg
Part B: 3 - 1/4in 20 U-type Speed Nuts
http://i131.photobucket.com/albums/p...n/100_1383.jpg
Part C: 6 - 1/4in x 1in Cap Screw Socket (Stainless Steel) I purposely used a different metal/finish because these are a different size.
http://i131.photobucket.com/albums/p...n/100_1379.jpg
Part D: 6 - 1/4in 20 x 12.5mm Insert Nuts
http://i131.photobucket.com/albums/p...n/100_1380.jpg
Part E: 13 - #12 Finish Washers
http://i131.photobucket.com/albums/p...n/100_1382.jpg
Now onto the installation:
#1 We'll start with the 2 front Engine Covers. There are 6 attachment points for these 2 covers. You will need 6 of Part C, 6 of Part D, 6 of Part E. Start with removing the engine covers and enlarging the 6 attachment holes where the push pins go. Don't over large as you want part D to fit snuggly. Here is what it will look like once the part is pushed into the plastic.
Example 1: Far Right Side
http://i131.photobucket.com/albums/p...n/100_1384.jpg
Example 2: 2nd from Right
http://i131.photobucket.com/albums/p...n/100_1385.jpg
Example 3: Far away shot of 2 of theseattachment points.
http://i131.photobucket.com/albums/p...n/100_1387.jpg
Once this is done you can sit the 2 covers back on and use 6 of Part C and 6 of Part D to attach at each point. Here is an example of 1 attachment completed.
Example: Now this sits a little high and will actually touch the under side of the hood, but I wanted to be able to loosen and remove by hand rather than always having to use an allen wrench. You could opt for a flat head screw if you'd like.
http://i131.photobucket.com/albums/p...n/100_1393.jpg
# 2 Coolant Cover: This is a piece of cake. You'll need 1 of Part A and 1 of Part E. It simply screws in where the old audi screw used to be. Here is the finished product.
Example:
http://i131.photobucket.com/albums/p...n/100_1402.jpg
# 3 Battery Cover. This is also a piece of cake. Use 3 of Part A and 3 of Part E. They also simply screw in where the old audi screw used to be. Here is a shot of 2 of the 3 points.
Example:
http://i131.photobucket.com/albums/p...n/100_1394.jpg
#4 Engine Cover. This is a little more involved. We are going to use 3 of Part A, 3 of Part E, and3 of Part B. You will need to use Part B in place of an old pressure clip that held on the 1/4 turn screw and the cover attachment points. The old clip pops out and the new 1/4in U Clip slides right on. There is a pic of this. Once you complete this task simply attach the engine cover the same as the coolant and battery cover.
Example 1: The U Clip in place of the old pressure clip at the engine cover attachment point.
http://i131.photobucket.com/albums/p...n/100_1388.jpg
Example 2, 3 and 4: Engine Cover attached.
http://i131.photobucket.com/albums/p...n/100_1398.jpg
http://i131.photobucket.com/albums/p...n/100_1397.jpg
http://i131.photobucket.com/albums/p...n/100_1396.jpg
Now you're completely finished and hopefully with better (more sercurely)attached engine covers. I also hope this write-up helps atleast 1 person. Its a pretty easy and straight forward installation. It also cost less than $20 total for all the parts.
Please PM or post if you have any questions and I can take extra pics and post if you'd like.
MeanAudiA6 Apr 18, 2007 11:31 PM
RE: DIY Engine Cover Hardware Write-up LOTS of pics.
i like those better than the 42 draft designs....was this a local hardware store or a lowes or Home depot?
diehlryan Apr 18, 2007 11:33 PM
ORIGINAL: MeanAudiA6
Everything but the U-Type Clips were bought at Home Depot. I couldn't find the clips at Home Depot so I went to Lowes.
diehlryan Apr 19, 2007 12:23 AM
The reason I used 2 different size Cap Screw Size Sockets was because I could not find a metric insert where the 2 front covers would attach.
Dana Reed Apr 19, 2007 05:43 AM
Thanks for the writeup and pics - very helpful, and a big improvement over the stock plastic junk!
