does the clutch pedals really vibrates?
does the clutch pedals give you a little bit of vibration when driving?
RE: does the clutch pedals really vibrates?
mine never did but you should not have your foot on the pedal while driving even just resting on it you will wear you clutch faster!
i dont rest my foot on the clutch but i feel it everytime i lift it off
how many miles are on the car/clutch?
i had an eclipse long time ago the clutch pedal vibrated turned out the heat bent a bracket and a spring got loose but i have no ide for audi but i do know for sure it should not vbrate
Mine does not vibrate.
think of it asa left foot massage. |
ORIGINAL: hotgrass does the clutch pedals give you a little bit of vibration when driving? |
He has one for the front wheels and one for the rear wheels! You must not own a quattro? Quattros gots two trannys, therefore two clutches =P:)
ORIGINAL: beachchair ORIGINAL: hotgrass does the clutch pedals give you a little bit of vibration when driving? |
ORIGINAL: Red_sapphire89 he has one for the front wheels and one for the rear wheels you must not own a quattro quattros gots two trannys therefore two clutches =P:) [sm=jawdrop.gif] |
i only have 35000 on it, im a new owner, i need to process my warranty transfer so i could take it to the stealership.
