DV sputtering
It's probably normal and Im not really toooooo concerned... but I figured I'd ask.
I was running the yellow spring in my DV with one shim. It felt very weak, so I swapped it with the blue spring. It feels much better now. However, if I go to accelerated pretty hard and change my mind (the boost climbs about half way and then I release the gas) I can hear the DV "sputter" for a second... is that normal? lol
Also, I can hit 24 psi of boost in any gear (other than 1st) by like 2300 rpms... I should probably adjust the onset on my BM huh? haha
Your explaination is a little hard to understand. You mean you get "futter" at low boost, (<10psi) that is normal for many dv/bov's. Holding the higher psi is the more important thing. I guess since you are seeing more boost means you have found the right spring. You dont HAVE to change the onset of your boost. You have a small turbo and thats what they do, spool early. So if you do, you just shortened your powerband.
**one final note, if you have 20+psi by 2300rmp's, YOU CAN'T CLAIM YOU HAVE LAG EVER AGAIN!!! That is withen 200rpms of a ko3(s).
You know... you're right. I guess it wouldn't even be considered turbo lag now that
i think of it. The thing is... even though my boost jumps to 20+psi at low rpm, I still don't start to get "throw back in the seat" pull until about 3k-3.5k. so yea, I have to say, I guess I was mistaken. It's not turbo lag, it must just be sluggishness getting the RPMs up to powerband level.
this is true...but i like to sell the old stuff off my car so i try and keep it in the best condition possible.....pissed my step dad threw away my old rear sway bar....i could have gcotten like 50bucks for it...lol....figure a used K04 with little shaft play(hopefully) could be worth at least 150 bucks or so.
$150 is about what most stock turbos seem to go for on vortex. But agreed, selling stock stuff is a great supplement for new parts. Got my wilwoods for ~$900 and offset that by $225 for the sale of my stock brakes to someone with a regular gti.
