If you have power-adding modifications on your MKI Audi TT, the next upgrade is more stopping power.
The ECS Tuning 302mm two-piece Tru-Float rotors increase swept area and braking torque without weight penalty. Precision-machined caliper carrier brackets space out your stock brake calipers to match the new rotor, and ECS Exact-Fit brake lines provide pad-squeezing fluid pressure.
Designed as a compliment to your ECS Tuning Front Big Brake Kit, this Stage 1 direct-fit kit helps you keep your speed in check.
Kit includes:
- 2-piece 308mm ECS Tuning Cross-Drilled & Slotted Brake Rotors
- Caliper carrier mounting brackets
- Mounting hardware
- Exact-fit line designed in house here at ECS with custom-made brackets for a clean install
I like. Big. Brakes and I cannot lie
Click HERE to order or for more information
Fits:
MkI Audi TT 180hp FWD
Be sure to check out our -----> Installation PDF <-----
Let me know if you have any questions.
Jason
