ECS wheel spacers....problem *EDIT*
I got the 15mm and 20mm spacers from ecstuning.com and went to put them, but the diameter of the hole in the spacer was too small and they would not fit over the wheel hub? I thought this was pretty weird because they are made specifically for audi and vw applications. Anyone else with these spacers have the same problem? **EDIT** I also bought the metal thing from TTstuff.com that you screw in to where the lug bolts go, its the same thing as the oem plastic piece but metal, it would not screw in all the way because it was too big. Anyone else buy this and have the same problem? I cant find it on their website so maybe they realized it didnt work and stopped selling it?
do you have hubcentric rings on your car? i forgot to take one off of one hub and was about to lose my mind when the 3 others fit and that one didnt.
then i found the ring, poped it off, and was good to go
what do you mean by 'not screw in all the way'?
How far are you trying to screw it in? You can screw thru the hub and you'll hit the ABS plate. If it goes in enough to support a rim, its good enough. Is it not even doing that?
