ESP
Old Sep 17, 2007 | 08:49 PM
myrodhTT's Avatar
Default ESP
Has anyone had there esp light come on without the mil light.......?
Old Sep 17, 2007 | 09:11 PM
ouTTie914's Avatar
Default RE: ESP
Not sure what a mil light is, but esp is your traction control.
Old Sep 17, 2007 | 09:14 PM
myrodhTT's Avatar
Default RE: ESP
cel sorry but i know that it has to do with the traction control but the light just stays on will not go off even when i push the button
Old Sep 17, 2007 | 09:16 PM
myrodhTT's Avatar
Default RE: ESP
the light with the triangle and exclamation point in the middle stay on is what i am acutally talking about not the light with esp letters
Old Sep 17, 2007 | 09:17 PM
ouTTie914's Avatar
Default RE: ESP
If you have a Check Engine Light vag your car, or go to Autozone and have them scan it.
Come back with the codes, and I'm sure someone will be able to help.
Old Sep 17, 2007 | 09:20 PM
myrodhTT's Avatar
Default RE: ESP
i think i am confusing you. my check engine light is not on just the other light. i only have chucks around here and i ahve already done that and there were no problem codes
Old Sep 17, 2007 | 09:34 PM
ouTTie914's Avatar
Default RE: ESP
Okay...
Make sure you have your 4-digit radio code, disconnect your battery; then reconnect after 5-10 minutes.
This will reset all codes and lights. Just make sure you have your radio code!
Old Sep 17, 2007 | 09:38 PM
diehlryan's Avatar
Default RE: ESP
ORIGINAL: myrodhTT
i think your maf is bad...
Old Sep 17, 2007 | 09:42 PM
myrodhTT's Avatar
Default RE: ESP
yeah i have already dissconnected the battery and the light was still on . i think its the maf too but i was sure so does anyone else have any suggestions ...... not say that yours suggestion are not good enough (outtie&diehlryan)
Old Sep 17, 2007 | 09:45 PM
ouTTie914's Avatar
Default RE: ESP
Ryan... How did you come up with MAF from traction lights?
Just curious...
