Fault code P1335 help!!
Old Jan 25, 2008 | 09:52 PM
SmoothTT's Avatar
Member
Default Fault code P1335 help!!
Problem: My epc light comes on and i loose power and i dont have any acceleration and then i turn my car on and off and it goes away but today i got the CEL and i got it diagnosed and the code P1335 came up. Does anyone know how to fix this problem...Please i need help..
Old Jan 25, 2008 | 10:07 PM
Red_sapphire89's Avatar
Default RE: Fault code P1335 help!!
do you know the deff of that code?
Old Jan 25, 2008 | 10:08 PM
beachchair's Avatar
P1335 - Engine Torque Monitoring 2 Control Limit Exceeded.
Old Jan 25, 2008 | 10:11 PM
o damn sorry i have no idea good luck hope ur audi isnt on a streak like mine so far this last 3 days um 1000+1600+800+200+?= add that bs up lol i wish i bought a 350z or vette or somethin rrrr
Old Jan 25, 2008 | 11:53 PM
ouTTie914's Avatar
Heh!
Sorry can't help but to giggle....
I've replaced my IAT sensor, throttle positioning sensor (new gas pedal assembly), maf, coolant temp sensor, PCV valve (flat one off the air box), breather valve, new DV; in attempts to get rid of this damn code and EPC light!!!
What TT do you have, and where did you get flashed?
If it's AWE tuning in Willow Grove, you're more than welcome to come with me on Monday or Tuesday to "resolve" this issue!
My EPC and P1335 started 4 days or approx. 150 miles after being flashed...
I feel your pain! [:@]
BTW you can turn the car off while it's moving and restart it.. Just make sure your in neutral, and try not to do it at night.
Other drives really don't appreciate your headlights going off and turning back on...
Edit: Oh yeah, I also met this other TTer at a local tuning shop by my parents house in NY.
He drives an 01 180 quattro, and had the same damn problem with his GIAC flash...
He switched to REVO and the problem disappeared...
Old Jan 28, 2008 | 10:35 AM
SmoothTT's Avatar
Member
i have a 2000 180hp quattro ..and yes i got it done by AWE tuning lol haha. well i just got off the phone with them and they are suggesting that is not the sofware and they think i have a boost leak so back to square one with me : (
Let me know how everything works out after you get it reflashed i just dont want to take the drive out there, in the mean time im gonna check if i have a boost leak.
Old Jan 28, 2008 | 11:27 AM
ouTTie914's Avatar
What a co-quinkie-dink!
Quickest way to check for a leak is to install a boost gauge. You should have one anyway!
Once you find out that's not the problem; I think it'd be really interesting for both of us to go there at the same time.
I was told "We've never heard of this problem before, we'd need at least 3-4 days to really dig into your car."
^That's not cool with me!
After telling them by boost gauge readings I was also told "That doesn't sound like typical limp mode, because even then you can still drive the car."
I hope in your case it is just a really big boost leak!
Best of luck to you!
Old Jan 29, 2008 | 02:55 PM
SmoothTT's Avatar
Member
thanks im going to check for any boost leaks but keep me updated with ur situation.
Old Jan 29, 2008 | 05:05 PM
DurTTy's Avatar
are you sure there are no other codes stored in there? you should get it cleared and see what happens to it then go ahead and wait till epc comes on again.
btw the max tq /mx boost exceeded happened to me when i cranked up my MBC past the program limits of my flash. i cleared those codes and they never came back
Old Jan 29, 2008 | 08:17 PM
SmoothTT's Avatar
Member
yea i got it cleared and it hasnt come back yet but i know it will but i did the same last time so hopefully it doesnt comea back at all..got my fingers crossed..
