AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   Fault code p1340 (https://www.audiforums.com/forum/audi-tt-7/fault-code-p1340-89858/)
martinezadamjbd Jan 31, 2008 07:34 PM
Fault code p1340
Hey people I just got this 2000Audi TT quattro 2 days ago with the check engine light on and today when I went to smog check it the car passed everything but the engine light....The code that came up is p1340 camshaft position sensor or something like that, my question is have any of you delt with or heard of this problem before?
theTTkid Jan 31, 2008 07:36 PM
RE: Fault code p1340
mine did that, just took it to the shop for fix though
martinezadamjbd Jan 31, 2008 08:54 PM
Just so I know what im gonna be dealing with about how much did you pay to fix the problem?
beachchair Feb 1, 2008 05:09 AM
ORIGINAL: martinezadamjbd
The actual Diagonstic Trouble Code P1340. For what it's worth.
Crankshaft-/Camshaft Pos. Sens. Signals Out of Sequence.
martinezadamjbd Feb 1, 2008 11:57 AM
cool thanks
MeanAudiA6 Mar 17, 2008 02:32 PM
hey ttkid check your shop receipt and see what they replaced....just the cam sensor? its around 100 bucks on ecstuning.com
ouTTie914 Mar 17, 2008 02:35 PM
1 Attachment(s)
If you were wondering where the sensor is...
Attachment 58767
MeanAudiA6 Mar 17, 2008 02:43 PM
thanks becca i figured thats where it was....i have no idea why it wouild go bad...but thats autoparts for ya...if its the Orig then i understand lol
techbod Mar 17, 2008 02:51 PM
out of sequence my data says ( is it lose? is the wiring ok and the connector plugged in tight ) I had that problem with a vauxhall omega[:@]because it was an inline engine and the cam sensor was on the front of the engine and above the rocker cover so every time I leaned over the engineer it upset the cables
Red_sapphire89 Mar 17, 2008 02:53 PM
Mine threw that code turned out the timing belt had stretched....
