Finally!
Just got off the phone with my mech. and he had already ordered the aluminum fly. I was hoping he would call before he ordered but i'm running out of time. I'm pretty freakin excited though. Its like i've been driving in limp mode for the past 3-4 months. I forget what itslike to have boost!
Ok just got my car back thank god! Man it spools up much quicker than it used to, well then I can remember. I also had the pendlum mount from vf engineering installed. its like a whole new car. I stalled out a couple of times trying to get used to it. It catches much quicker almost immediatly from when I lift my foot off the clutch. The flywheel is loud as hell! I think i may need to take it back cause it chatters while i'm in gear as well. I may need a throw out bearing replaced. Or it could be normal. All in all, i'm glad to be able to boost again. I'm hittin just over 20 and sticking! So glad!!!!
God, I'm dreading my clutch mod.
I swear im gonna do my BT in Feb. I just seem to be not getting all the rest of the stuff in the timeline I hoped. I still dont have my suspension or clutch. Grr.
I guess I can get the suspension AFTER the bt if need be, but the clutch has GOT to be before.
******-A, I better get a clutch soon. SPEC Stage 2+
ftw
ftw
ORIGINAL: moeron7
What does the throw out bearing do exactly? And anybody with this clutch, does this sound normal at first? Does it not sound as bad after I break it in?
Purpose: When the driver steps on the clutch pedal, the throw-out bearing applies force to the fingers of the spinning pressure plate to release the clutch. When the clutch pedal is released, the bearing sits idle and does not contact the pressure plate fingers.
Maintenance Tips/Suggestions: The classic symptom of a worn throw-out bearing is a whirring or growling sound when applying the clutch pedal, which goes away when releasing the pedal. Premature wear of the throw-out bearing can occur when there is insufficient clutch play, resulting in a throw-out bearing that spins continuously. If the bearing fails, it may seize and quickly wear the fingers of the pressure plate. The throw-out bearing does not require routine maintenance, but should be replaced when clutch replacement becomes necessary. Consult a professional technician to determine whether the throw-out bearing or other parts of the clutch assembly need replacement.
hope that helps
ORIGINAL: neur0tic
SPEC Stage 2+ ftw
SPEC Stage 2+ ftw
ORIGINAL: cincyTT
I have seen to many spec's eat themselves. Its either a great clutch or the worst available. I was thinking sach's but neither sach or spec hold 350Tq unless you spend over $600. So since my engine is out and clutch easily exposed, im going to go with a ACT w/ street disk good for 340Tq and should feel almost like stock. I have used ACT before in my turbo lancer and loved it so im getting them again. Total should be right around $500 for the clutch and a eurospec 14lbs steel FW
ORIGINAL: neur0tic
SPEC Stage 2+ ftw
SPEC Stage 2+ ftw
Dont know what kind of torque that'll be. You have any idea or know any good clutch combos that meet those specs for under $700?
