forge tip help
Old Apr 20, 2007 | 01:05 PM
twenty8red's Avatar
Default forge tip help
i think my forge tip may have come off the turbo or possibly has never been on properly. i can't see down into the engine bay well enough to check it. i'm going to try to get it on jack stands this weekend to check it from underneath but don't know if i'll get a chance. what should i be looking (listening)for if this has occured, would my turbo still spool, dv still dump? i just installed a new maf and may have somehow jarred it loose. it ran great for about a week then my check engine light came on. any help would be greatly appreciated. thanks.
Old Apr 20, 2007 | 01:09 PM
patty AT forge's Avatar
Default RE: forge tip help
Do you have the ability to pull the code?
Old Apr 20, 2007 | 01:11 PM
twenty8red's Avatar
i could probably stop by autozone on sunday but i don't have anything personally.
Old Apr 20, 2007 | 02:06 PM
cincyTT's Avatar
I'm make believe
The tip connects the intake to the turbo. The turbo spool and dv will still work, but if it is off (even partailly), you are using unmettered air and the air that was mettered may not be going into the turbo. If you get another maf code it could be a possiblilty. You should be able to see it from the top, just remove the engine cover and peek from the driver side fender. Underneath is a much better veiw though.
Old Apr 20, 2007 | 07:33 PM
twenty8red's Avatar
i got an inspection mirror and i'm going to take a look when i get home. i'll try to get it on some jackstands sunday to get a better look. i hope that's all it is i'm tired of seeing that cel.
Old Apr 23, 2007 | 11:25 PM
twenty8red's Avatar
ok now, today after work i started my car up and the cel did not come on like it has for the past week. i wasn't able to do anything to my car this weekend so i know it's nothing that i did. wtf? are there any reasons for an intermittent cel?
Old Apr 23, 2007 | 11:46 PM
cincyTT's Avatar
I'm make believe
It is possible to get codes and for them to correct themselves. Its usually nothing serious, but it does happen.
NuYorka103185
May 18, 2011 01:13 PM
vegastt
Sep 4, 2007 12:18 AM
blaznD
Jul 1, 2007 02:26 PM
.clipse
May 15, 2007 11:55 AM
dtmguy
Apr 16, 2007 03:24 PM
