FS: New Greddy G2S Dual Exhaust System (225HP)
ORIGINAL: joshuo
is it dual tip or single?
ORIGINAL: cincyTT
Dont get the neuspeed one, in the sound clips it sounded horrible. The worst of the bunch.
. $20 to weld in a straight pipe in where the resonator was. so worth it. should sound alot better once i throw in my 3" DP.
ORIGINAL: ttoo cool
I wish I had purchased it myself as it is much cheaper than the APR I purchased even with a 25% off discount.
Yeah, the APR system is expensive
I'm not exaggerating either, sourced from SAVwKO's stock turbo tuning guide:
GIAC X+ ... $500
4.3v Diode ... $2
Oil Catch Can ... $30
Cranked Wastegate ... FREE
(27psi Spikes, 15psi @ Redline)
GHL 3†Turboback ... $1000 <-I'll subtract the exhaust system, obviously
Lemmiwinks Tuned ... FREE
Samco Turbo Inlet Hose ... FREE
ECS Magnetic Drain Bolt ... $10
NGK BKR7E Spark Plugs ... $12
Custom Hardline DV Return ... FREE
Golden Eagle Vacuum Manifold ... $75
Custom Front Mount Intercooler ... $400
ESE Colormatched Cold Air Intake ... $250
Relocated Forge 007 Diverter Valve ... $125
Bosch 4-bar Fuel Pressure Regulator ... $55
ECS Lightweight Underdrive Pulleys ... $120
Enginerd Coilpack Hold-down Brackets ... $35
Boostvalve Dual Stage Boost Controller ... $120
Custom 3-way switch
*Low*High*Low in 1st ONLY*
Newsouth Performance Powergasket Plus ... $70
N249 and Secondary Air Injection Deleted ... $10
Boost Cooler Water/Methanol Injection ... $370
TOTAL: $2184 I'll guess close to $2500 total. (adjusted as per subtraction of exhaust price)
4.3v Diode ... $2
Custom 3-way switch
So yeah. Not ragging on your purchase beef, I know your reasons, but damn! That is one expensive metal tube.[sm=insomnia.gif]
ORIGINAL: beefyosito
Yeah, the APR system is expensive, but it is so well made and it sounds great.
Take a look here
jgcleary
Jul 2, 2012 01:30 AM
