glowshift gauges help!
i have yellow, black (which is the ground) and yellow and purple. i have the regular black 7 series. can someone give me a schematic or does any body knows where i should put the wires?
I put mine in the same place.
I got a add a circuit from autozone for the possitive line.
As far as the negative I put it under one of the bolts that are screwed into the side panel.
Get extrawire, have your vent assembly ready, wire crimpers all that good stuff.
I didnt even use the yelow I actually just left it alone.
I connected the possitive to the add a circuit for an accessoryfuse thats active when I turn the ignition.
Im sure someof this doesnt make sense try this PDF
or PM me.
or PM me.
