Haldex problems
i bet its working most of the time.
i've posted 'the haldex roll out test' procedure a couple of times here, try that, both when you think the car is acting fine, and after a long highway drive.
I can tell you for sure that there is an operating range, both high and low, that the haldex won't engage. The numbers I can't remember. I doubt the dealership would be much help either, but there is info on the web. I just f-disked my PC that had a bunch of haldex info on it, or I'd send you the PDFs I'd found.
and your right haldex is not engine related so that just shows again what i have will not show anything. I would have to use vag-com or go to the dealership.
no no no.
fluid is haldex fluid. not gear oil. comes in what is essentially a caulk tube.
You SHOULD be able to get fluid and filter from the dealer if you need to do it NOW, but you'll pay more. ECS sells it for a little less, and if this is your first time changing it, and it sounds like it is, you'll also need a filter wrench.
Fluid and filter from ECS is $70. WITH the schwaben filter wrench is $126. I use 'the H-wrench' which I believe is only sold thru the modshack at this point, for $50. Mine is serial number 018, I got in early when Warren aka StillJester on AW was selling them direct for $40.
oh, and you'll need to either:
A. get the car high enough you can hold a caulk gun with the plunger fully extended vertically under the rear of the car.
or
B. Get a short piece of hose you can push into the drain hole of the haldex unit, and onto the end of the caulk tube so you can push the fluid in from an angle.
Either way, old fluid comes out of the drain, new fluid goes back in the drain, and then you quickly put the drain plug back in place spilling as little as possible. Option A is the one to go for if you can, since the tapered end of the caulk tube will seal around the drain hole easily.
You're given slightly more than you need to fill the unit because its expected you'll spill a little, so don't totally freak out if you don't get it ALL in.
What works best for me is to pull the caulk tube away, and quickly put my thumb over the drain. Have the drain plug and hex wrench close by, and with your free hand get the plug on the hex wrench, then quickly swap your thumb for the plug. Usually don't loose more than a drop or two.
or
Yes ^^ Change your fluid and filter. I bet your fluid is low and it's over heating. It cant hurt, since it's due every 20k.
I also have the modshack filter tool. Works good and cheep. Looks like a huge socket.
