help needed!!!!!!!!!!!!
Old Nov 7, 2007 | 03:53 PM
m3yer's Avatar
Default help needed!!!!!!!!!!!!
help needed in this picture shown i have put a bailys dumpvalve on my tt 225 and blanked the original bosch one off was this wise? because i want to put a boost controller on, but i mostly hear people putting a dv is this a replacement of the original bosch?
http://imajr.com/TT_ENGINE_BAY_439023
Old Nov 7, 2007 | 03:58 PM
ouTTie914's Avatar
Default RE: help needed!!!!!!!!!!!!
[sm=ttiwwp.gif]
Sorry couldn't resist!
Now that that's out of the way... Where exactly did you put your new dv?
Most people just take the old one out and put the new one back in it's place.
I'm not sure how a boost controller would get in the way, but then again I don't know that much about them.
However, there are a few around here that have their dv in the stock location and run a boost controller...
Old Nov 7, 2007 | 04:01 PM
ouTTie914's Avatar
What you have circled in that picture is your fuel pressure regulator...
Old Nov 7, 2007 | 04:02 PM
m3yer's Avatar
i have just put a dumpvalve on no boost valve yet just wondering if i have done the right thing by putting a dumpvalve on the intercooler pipe instead of it being where the original one is?
Old Nov 7, 2007 | 04:03 PM
m3yer's Avatar
thats not me that was the support team when they emailed me the pic to show me where to put the dumpvalve thats nothing to do with me
Old Nov 7, 2007 | 04:06 PM
ouTTie914's Avatar
As long as it's between the turbo outlet and the throttle body you should be okay.
Old Nov 7, 2007 | 04:09 PM
m3yer's Avatar
so it does not matter that the old bosch one has een removed they told me to do it the supplier but if there is nothing there wont i lose power?
Old Nov 7, 2007 | 04:16 PM
ouTTie914's Avatar
If you removed the old, and replaced it with your new dump valve... What's the problem?
I guess a better question is... Where was the original valve that you took out...
Old Nov 7, 2007 | 04:23 PM
m3yer's Avatar
the original one was just after the intake behind the airflow meter i was told to cut it off blank it up then put the new dumpvalve on the pipe after the intercooler by the front of the engine
Old Nov 7, 2007 | 04:25 PM
cincyTT's Avatar
I'm make believe
If you are venting the air, you need to plug the intake and put it on the charge pipe. If you are recirculating the air back to the intake, you should have the valve on the intake and pulling air from the charge pipe with the stock hose.
