How do you remove the door panels??
Does anybody had removed the door panels? It seems that only the dealer has this info and they are not willing to help if you are not bringing the car to them.
I nee to remove the passanger side door panel. I hear something ratling inside the door and I'm afraid this will get worse. I suspect one of the window guides is loose. The window feels a bit loose compared with the one on the driver side. Can anyone provide me with detailed steps on this issue?? Thank you. |
RE: How do you remove the door panels??
Thank you for the link. I checked it out but none of the instructions apply to tt's. I believe that procedure is for an older "A" series models. I have ordered the Bently repair manual. I should get it soon.
Thanks Luispv |
I got the same question, Anybody can help me? I bought the front and rear speaker but I still can not install them![:@]
I got the intructions to remove the door panel trim.
NOTE: BEFORE YOU BEGIN REMOVING THE PANEL, FIRST REMOVE THE RUBBER MOLDINGS THAT SURROUND THE WINDOW. YOU CAN DO THIS BY INSERTING A FLAT SCREW DRIVER AND PUSHING UP THE TWO MOLDINGS THAT TOUCH THE WINDOW GLASS. 1.- Remove the Screw cap located on the door handle. At the bottom of the screw cap there is a small hole. Insert 1/16" pin in it and press up while turning the screw cap. I used a small allen wrench. Turn the screw cap about a 1/4 turn. The screw cap will come off easy. 2.-remove the screw in the door handle. 3.-Lift the door panel about 2" and pull it out. There is a cable and an "S" hook attached to the handle that opens the door. Detach the hook using your fingers. There is also an electric plug that needs to be disconected. You are done!!! NOTE: WHEN INSTALLING THE PANEL BACK, BE SHURE THE LOCATING PINS ARE INPLACE PROPERLY AND THE "S" HOOK IS FACING UP. |
Any suggestions on how to get the rubber "pegs" on the rubber end trim back into their holes? Tried force, tried soap, ready to try some heat....
