Idle Drop!
Old Mar 21, 2007 | 08:47 PM
moeron7's Avatar
Default RE: Idle Drop!
ORIGINAL: XCLR8TT
Until you eliminate the vacuum/boost leak or the dirty throttle body as a source, the rest of the realm of possibilities is mute. You need to exclude the most common/obvious first.
How would I check for a boost leak or dirty throttle body? Any links?
Old Mar 21, 2007 | 08:59 PM
achTTung's Avatar
buy or build.
http://www.modshack.info/Pressure.htm
I built one for under $20
Throttlebody would need removal, or at least a good look at with a flashlight.
Old Mar 21, 2007 | 09:12 PM
moeron7's Avatar
Noob question alert! Where is the throttle body?
Old Mar 21, 2007 | 09:18 PM
achTTung's Avatar
I'll give you 2 hints. Its attached to the intake manifold, and the engine is attached to the other end of the manifold.
Old Mar 21, 2007 | 09:36 PM
moeron7's Avatar
ORIGINAL: achTTung
LOL still no clue. I'll look it up when i'm not so busy at work.
Old Mar 22, 2007 | 03:02 AM
krnaudi's Avatar
My car seems to do that too, the idle moves around from 700-1000 rpm at time to time.
Old Mar 22, 2007 | 11:36 AM
stephenson27's Avatar
I had the same problem and after doing a tune up it went away. While I was searching the problem out though I used Limmewinks to increase the rpm's when idling to keep her from dying on me and the embarrassment. It by no means is a fix and shouldn't be used as one.
Old Mar 22, 2007 | 02:09 PM
  #18
moeron7's Avatar
I'm gonna check my TB this weekend and see if its dirty. If not, exactlywhich pipes/tubing should I look for leaks?
Old Mar 23, 2007 | 03:47 PM
  #19
sound227's Avatar
Mine does this too, but not as extensive. Usually it hoves between 700-800, but every once and a while at a light it drops down to 600 or so and I give it a rev to bring it back up (habit from driving my talon I guess). Is the 700-800 fluxuation normal, or should it hold steady at 750?
muckdawg24
Aug 23, 2008 06:01 PM
freestyleski
Oct 8, 2007 11:09 PM
kingtut
Sep 19, 2007 10:36 PM
adexplosion
Dec 19, 2006 05:19 PM
