Idle issue
Old Mar 1, 2008 | 10:30 PM
Inibalir's Avatar
Default Idle issue
Hi, my idle is sitting at like 800 rpm and then it drops to like 500 rpm then shoots up to about 1300 rpm then back down to 800 rpm. From what I've read here it sounds like the MAF. I tried cleaning it and that seemed to fix it for a few days. But now its back not too long later. Do you think it is the MAF and that it needs to be replaced? How much do they typically run?
Thanks!
Inibalir
Old Mar 1, 2008 | 10:56 PM
jakej's Avatar
Default RE: Idle issue
prob the maf. Try to unplug it and see if it makes a difference. They are around $120 to replace. They have an extended warranty untill 7 years/70k miles though. Also- sometimes you can clean it. Do a search for more details.
Old Mar 1, 2008 | 11:26 PM
themysteryman83's Avatar
Sounds like a vacuum leak. Check your hoses for cracks or looseness. If it does it over and over in the span of a few seconds it would sound like a classic case ofvacuum leak. MAF problems would give studdering issues all over the rpm range.
Old Mar 3, 2008 | 02:26 PM
Mac_17's Avatar
Yeah I have my car in the shop right now for that I will let you know what it is.
Old Mar 3, 2008 | 02:58 PM
chosos's Avatar
we should start exporting faulty MAF's to users with low mileage cars. lol. ;-)
i cant believe how often these darn things fail. something about that situation isnt right.
Old Mar 3, 2008 | 04:02 PM
tom1222's Avatar
ORIGINAL: chosos
My 04 is still going strong on the same MAF after 55k miles. Maybe everyone is just blaming all their problems on a faulty MAF where it could just be a simple (or not so simple in case of the TT)
vacuum leak.
[8D]
Old Mar 3, 2008 | 08:06 PM
kbevere's Avatar
ok im new to having my own TT so what is a MAF? and also will this also have anything to do with me having to pump the gas a few time to get the car started on very cold days? i seem to have to the pass few weeks. we been having some cold mornings.
Old Mar 3, 2008 | 08:15 PM
Red_sapphire89's Avatar
Old Mar 3, 2008 | 08:18 PM
kbevere's Avatar
ok not that i know what that is but thanks
i really need to learn how to hook up this car.
Old Mar 5, 2008 | 08:34 AM
chosos's Avatar
i knew nothing about cars when i bought mine.
i've already replaced (on my own) the timing belt, t-stat, water pump, o2 sensors, spark plugs, coil packs, maf, coolant temp sensor, 2 o2 sensors, added a boost gauge, added an mbc, and countless other things. this car makes me learn cars. lol.
