I'm gonna need some advice - timing belt failure
Old Sep 13, 2010 | 09:08 PM
dtb2253x's Avatar
Default I'm gonna need some advice - timing belt failure
2001 225HP Roadster. 59,100 mi. My timing belt failed yesterday, at idle. Of course, not knowing what happened, I tried repeatedly to restart it. So, if the engine wasn't damaged by the failure, I'm sure it is now.
So, I do have the skills to fix it, but a little help is always nice. I've read the step-by-step "how-to" that is somewhere on this site. That is the best technical document I've ever seen!
I have a manual on order.
I have started the tear down. I figure the head is going to have to come off, and I am working on it. I have everything off the head except the exhaust manifold. My questions:
-How in the heck do you get to the exhaust manifold bolts. How many and what head size/type?
-Can the head bolts be reused or are they stretch bolts?
-Anyone got a good used AMU head with valve train they want to sell?
-I've only owned this one for 8 months - any chance of some partial comp by Audi due to the Class Action?
Sorry this is so long. Thanks in advance.
Old Sep 14, 2010 | 10:30 AM
cincyTT's Avatar
I'm make believe
Manifold to head is 13mm bolts, Some 225's have an odd turbo to manifold bolts which i cant remember what they are since my 180 has 17mm bolts.
They are stretch and need replaced or it will fail. They are cheap to replace
Any 1.8t head will do (VW or Audi). The only difference will be if it has vvt or not. The AMU does not so you will need to swap the cam tensioner if you find one with vvt or since its a good time and wears quickly, replace it since the non vvt tensioners are cheap
-I've only owned this one for 8 months - any chance of some partial comp by Audi due to the Class Action? Nope. Next time change it at 60k or change to a manual tensioner that wont fail
Old Sep 14, 2010 | 10:41 AM
MafiaBoy's Avatar
It is a lot easier if you first remove the 3 turbo to exhaust manifold and remove the head with the exhaust manifold. Then remove the exhaust manifold,
Old Sep 14, 2010 | 01:44 PM
dtb2253x's Avatar
Default Thanks, mafiaboy
I've been looking at it and am thinking the same thing. Your advice just confirms it. I appreciate it.
Old Sep 14, 2010 | 11:58 PM
MafiaBoy's Avatar
Yeah. Been there, done that.
zoewagner
Apr 14, 2013 07:32 PM
gary1005
Jun 28, 2010 07:06 AM
a2thy
Aug 5, 2009 12:44 AM
snogoer
Aug 3, 2006 01:59 AM
davehurwitz
May 8, 2004 01:52 AM
